tub surround removal
Ray | Posted in General Discussion on March 21, 2009 03:02am
I have a plastic tub surround that’s held on with construction adhesive.  Is there an “easy” way to remove it or is crowbar & muscle the only way?
  1. YesMaam27577 | Mar 21, 2009 03:29am | #1
    C-4 usually works well.
    Politics is the antithesis of problem solving.
    1. Ray | Mar 21, 2009 04:06am | #2
      Fresh out of C-4, do you think napalm would work?  :-)
      Unfortunately, I was afraid of that.  We're going to install tile, so if the wall is drywall or plywood, it will be "rippable".  Hardieboard will cover a lot of damage.
  2. USAnigel | Mar 21, 2009 04:18am | #3
    Cut the wall material around the old surround and pull it out. Replace with hardy backer.
    Wear gloves and mind the edges they can be very sharp!
    1. chairmon | Mar 21, 2009 07:18am | #4
      You are right on. The area should be back to the studs for the backer anyway. Cut it out and install the CBU's.Craig
      Edited 3/21/2009 12:18 am ET by chairmon
    JeffBuck | Mar 21, 2009 07:28am | #5
    if it's a thinner one just glued to the wall, they usually just peel off.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
