Tubing cutter vs. pipe cutter
| Posted in General Discussion on May 18, 1999 03:32am
Needed to cut some 2″ DWV copper and my tubing cutter only went to 1 1/2. Priced a new Rigid 2″ tubing cutter at the local plumbing supply: $65. Even if I had the time to drive to HD, I’d expect it to be better than $40. As it happened I’d seen a Rigid 2″ pipe cutter at a local used tool place and got it for $19.
My question is: is there any difference in the cutting wheel in that big hefty pipe cutter and the cutting wheel in the compact tubing cutter? The pipe cutter seemed to work fine on the 2″ DWV tube, but did compress the end of the tube slightly. It reamed out fine. Would a tubing cutter do a better job?
  1. Mike_Mahan | May 17, 1999 03:58am | #1
    The pipe cutter will cut tubing but not verse visa. Plumbing supplies often have better prices on Ridgid stuff than HD.
    1. DScott_ | May 18, 1999 03:32pm | #2
      *Thanks for the info and spell-check Mike.
  2. DScott_ | May 18, 1999 03:32pm | #3
    Needed to cut some 2" DWV copper and my tubing cutter only went to 1 1/2. Priced a new Rigid 2" tubing cutter at the local plumbing supply: $65. Even if I had the time to drive to HD, I'd expect it to be better than $40. As it happened I'd seen a Rigid 2" pipe cutter at a local used tool place and got it for $19.
    My question is: is there any difference in the cutting wheel in that big hefty pipe cutter and the cutting wheel in the compact tubing cutter? The pipe cutter seemed to work fine on the 2" DWV tube, but did compress the end of the tube slightly. It reamed out fine. Would a tubing cutter do a better job?
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
