Tuff-Hide Primer… Opinions Please
kltzycrpntr | Posted in General Discussion on April 23, 2008 02:16am
Has anyone used Tuff Hide? Is it that much better than regular primer? Does it really help that much after the final coat of paint goes on the wall? Any and all input would be appreciated.
Here’s the link…
http://www.usg.com/navigate.do?resource=/USG_Marketing_Content/usg.com/web_files/products/prod_details/SHEETROCK_Brand_Wall_and_Ceiling.htm
  1. Faulted1 | Apr 23, 2008 04:32am | #1
    IIRC, Tuff hide is a product to provide a smooth texture to drywall (level 5).  In all practicality, it's thinned drywall mud.
  2. davidmeiland | Apr 23, 2008 05:08am | #2
    My drywall sub sprayed Tuff-Hide on our current job and I am now a big fan of it. They did a very clean Level 4 finish first, and then sprayed the primer. No sanding after the spray. It takes a fairly powerful pump to move this stuff, not your average spray rig. Big bonus for me is that I got a batch of clean, heavy 5-gal buckets.
    1. kltzycrpntr | Apr 25, 2008 03:23am | #3
      Thanks for the feedback. Now all I have to do is try to convince my painter to use this product.
      1. ruffmike | Apr 25, 2008 04:01am | #4
        Tuff hide is generaly done by the tapers, never heard of a painting contractor doing it.
        Our drywall company uses it at times on condo projects. David gave you a good image of it. There is a learning curve when it comes to spraying this product, not an easy diy thing.                            Mike
          BarryE | Apr 25, 2008 04:24am | #5
          might be regional, around here the painters do it, most of the drywallers have never heard of it and wouldn't have the pump to spray it with anyway.
          Barry E-Remodeler
          1. ruffmike | Apr 25, 2008 04:50am | #7
            That is interesting to me, as it is a USG product and sold at drywall supply shops.                            Mike
            BarryE | Apr 25, 2008 05:00am | #8
            Seems hard to find it around here, I've got one supplier who used to stock it, but it looked to have sat for quite awhile. That's why I went to Builders Solution, much easier to get
            Barry E-Remodeler
          3. ruffmike | Apr 25, 2008 05:41am | #9
            Hamilton has a similar product also; http://www.hamiltonnw.com/NewProducts.asp                            Mike
            BarryE | Apr 25, 2008 02:43pm | #10
            They have a supplier in this area, I'll check it outHave you used Hamilton products?
            Barry E-Remodeler
          5. ruffmike | Apr 25, 2008 03:51pm | #11
            Yes, but not the product posted. Their mud is a good quality. Sometimes we call it the Christian mud, each box has a fish and bible quote on the box.                            Mike
            BarryE | Apr 25, 2008 05:47pm | #12
            thanks, I'll check it out
            Barry E-Remodeler
        BarryE | Apr 25, 2008 04:27am | #6
        Might try doing a search in advanced search. This has been talked about quite a bit and you might find some more useful infoAlso Sherwin Williams has Builders Solution which is comparable to the Tuff Hide.I use it quite a bit and love it
        Barry E-Remodeler
