Turbine Ventilators
| Posted in General Discussion on May 8, 2000 11:46am
Can somebody give me an idea about different types of “Turbine Ventilators” available in the market and what factors to consider while selecting one? Also if you can recommend few good brand names ???
  1. Guest_ | May 05, 2000 06:55pm | #1
    manohar.. here's one... don't do it..
    they're designed for aggie buildings.. but they don't even work good there..
    in very windy situations they can seriously depressurize an attic
    in no wind situations they do nothing...
    use a ridge vent ,like Shingle Vent II,
    even mushroom vents would be preferable to turbines
    1. Guest_ | May 05, 2000 09:58pm | #2
      *Manahar. Mike gives good advice. A turbine vent(also called pots in the mid-West) is nothing more than a roof vent with a rotating ventilator cap. These vents ,whether fixed or rotatng, move only a small amount of air only in a small area immediately surrounding the vent.At low wind speeds the turbine vent performs no better or worse than other roof vents.High wind speeds causes excessive spinning which causes excessive wearing of the bearings. They often stick and fail to rotate. Years and years of testing shows they simplyu don't work. Many believe that while the rotsator is turning raoin or snow cannot enter the vent. But just as the rain an d snow enter otehe roof vents it enters the turbine vent. Hundreds of houses in Oklahoma havbe several inches of sand over the attic floor insulation brought in by turbine ventilators.. Turbine vents fail- as do gable end louvered vents--when there is no wind. Hope this helps. GeneL.
      1. Guest_ | May 05, 2000 10:27pm | #3
        *Manohar,Don't do it! The only thing I'll add to the above posts is that if you have several cars up on blocks in your front yard and a couple of used tire planters,decoratively speaking, they will fit right in. But I would still plug them up from the inside and screw the bearings tight.John
        1. Guest_ | May 06, 2000 03:05am | #4
          *The proper attire for those things is a trash bag and duct tape. Like diapers they require periodic changes as the UV gets to the plastic. Joe H
          1. Guest_ | May 08, 2000 03:14pm | #5
            *Manohar,Ain't it frustrating when you get such conflictin' advice?:-}Rich Beckman
          2. Guest_ | May 08, 2000 04:11pm | #6
            *There is nothing wrong with installing only one turbine vent. If you install more than one, however, you'll notice that they never turn at the same speed, and it'll drive you crazy.
          3. Guest_ | May 08, 2000 08:14pm | #7
            *b "you'll notice that they never turn at the same speed"Now that remark is the kiss of death for anyone wanting a turbine vent.Nicely put though! LOL
          4. Guest_ | May 08, 2000 11:25pm | #8
            *Here comes Mr. Contrary.I put a turbine vent at the back of my garage about 20 years ago. Never oiled it. Never even touched it, that I can remember. Still turns at the slightest breeze. Still dead quiet. Have never seen any indication of any weather getting through it.
          5. Guest_ | May 08, 2000 11:46pm | #10
            *Still ugly.........
  2. Manohar_Raut | May 08, 2000 11:46pm | #9
    Can somebody give me an idea about different types of "Turbine Ventilators" available in the market and what factors to consider while selecting one? Also if you can recommend few good brand names ???
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
