Two Stage Heat Pump is only using Stage 2
fassbinder | Posted in Energy, Heating & Insulation on October 25, 2017 08:51am
After switching over from Heat to Cool for the season my Two Stage heat pump goes directly to Stage 2 without even trying stage 1. The outdoor temp was around the upper 40’s at the time, which usuallly can be handled by it’s Stage 1 setting. It usually at least tries stage one for a certain amount of time.
Here are the simple troubleshooting steps I’ve tried.
1. Switched it back to Cool and set the thermo low enough to use the A/C….Ran normally, outside fan blade ran as typical.
2. Switched it back to Heat, but when I raised the thermo setting to start the heating cycle, instead of seeing the temp setting increase as I pressed the button it just indicated OFF.
3. I switched the dial to the Change Heat Settings and cycled through the programable settings for the day. Then after switching back to it’s Run cycle I was able to reset the Heat setting low enough to get it to turn on, but it went straight to Stage 2 heat.
I’m suspecting the thermostat is bad but I’m open to other theories or tests.
It’s a Lux TX9100E, just about 6 years old. No problerms at all until now.
  1. fassbinder | Oct 29, 2017 10:57pm | #1
    Replaced the thermostat and it's working fine now.
    1. DanH | Oct 30, 2017 07:29am | #2
      Yeah, it sounded like the T-stat, but I'm not really familiar enough with that setup to have offered an opinion.
