Two story slab on grade foundation footing in California
Cali_Kirby | Posted in Construction Techniques on November 24, 2021 06:58pm
I just looked all over the internet for a detail for a two-story slab on grade footing. I was wondering if anyone had called out #4 rebar instead of #5.
I am a building designer and always have to listen to my engineer. He calls out 2-#4 rebar top and bottom, 4 rows total, in my 12″ wide x 12″ into grade one story footings. He calls out #5 in my two-story footings.
But I was curious if I could use #4 rebar in a 15″ wide x 18″ into grade two-story footing.
Well, I didn’t find anything. No detail or thread that explicitly discussed this. Then a contractor called and I asked him. He said he has always seen 2-#5 T&B.
I thought I would post this to see if anyone had any comments on the matter. Also, if anyone asks this question in the future, maybe they will find this thread.
  1. mikemahan3 | Nov 24, 2021 09:48pm | #1
    The engineer says # 5; the contractor says this is standard practice; you have a contractor so you are probably not doing the work yourself. Why are you even asking?
    unclemike42 | Nov 25, 2021 09:22am | #2
    This is really a question for your engineer.
    trade-offs between dimensions of steel and concrete are not a simple matter.
    In California, the performance during earthquakes is of concern.
    Is there an economic impact you are concerned about?
