Tying additon to structural brick
JMac87 | Posted in Construction Techniques on July 25, 2014 01:00am
Looking for the right course of action here. Never dealt with this situation before during a remodel.
So I have a 1948 duplex. CMU foundation, double wythe structural brick on the 1st floor and standard wood framing on the 2nd floor.
We’re putting on a 2 story addition with crawlspace.
Now, the question here is how to properly tie the framed addition walls into the existing structure. I’m having a foundation contractor deal with the foundation (epoxy/rods), so that’s one less thing to do. My concern comes with tying the exterior 2×6 walls to the brick. On one side I just have 1 story of brick to deal with, however, on the other side I have the chimney to deal with all the way up. This is not an active chimney. It is simply used to vent the furnace and HW heater…and I’ll be converting to a high efficiency furnace at some point and moving the HW heater, so that I can abandon and cap the chimney for good.
Album of pics: http://imgur.com/a/GlHnG
Any questions, ask! Looking for the right way to do this to pass code. Do I simply drill holes in the brick, insert threaded rods w/ epoxy, caulk between brick and 2x6s, and tie my walls in that way? Any specifics to follow?
  1. oops | Jul 25, 2014 05:26pm | #1
    attaching framing to existing masonry
    Is the back masonry wall going to remain or is it going to be demo'd?  .
    Since the masonry wall is structrual, can't  you epoxy bolts into it  to anchor the new framing?
    The solid masony wall gives you more to anchor  to than the hollow cmu's.
    What does the plans that the city used to issue your permit call for?
    1. JMac87 | Jul 25, 2014 06:29pm | #2
      Only about 3' of that back wall on each side will be staying. I'll be putting in a header to support the 2nd floor and pocket it into the brick.
      Yeah that was my idea..to epoxy bolts into the brick.
      Our architect is nearly done with the permit drawings, so we'll know what is called for shortly. I just wanted to get some info before I'm knee-deep in construction.
