Has anyone ever heard of using typar/tyvec from Dupont as a moisture barrier under a new pine floor.The pine flooring is going to be installed over 3/4″ advanteck gold edge on the main floor and second floor.Basement is crawl space with cement floor.
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
How about plain old 15# felt? A lot cheaper than Typar.
Most wouldn't put anything there other than rosin paper.
Here. I just went to NOFMA's site and copied this for you.
First of all tyvec is NOT A MOISTURE BARRIER. It it suppose to allow mositure to go through.
But if the crawlspace was don correctly a moisture barrier is not needed.
But felt also serves as a slip plain to reduce squeaking.
