Type of cable question
DonK | Posted in Energy, Heating & Insulation on April 14, 2008 04:47am
Hello all-
I’m involved with building a slate patio down here in Va, in the middle of which is a pond. Landscaping is not typically where I spend my time, but it’s where I’m at. Anyway, the homeowner, who is playing G.C. wants to get power down to his pond patio from a nearby building. He wants to use an old coil of grey colored #12 cable that he has. I looked at it and didn’t see anything that said it was underground cable. Rather, it said “UV resistant” or something similar. This doesn’t set right with me. Any thoughts on what the cable is? Could it be used in conduit? I think there were 4 conductors and the cable seemed pretty “flat” – like twice as wide as typical romex.
Any thoughts would be appreciated. For the record, I’ve already suggested that he get an electrician. 🙂 I’m not an electrician and don’t play one except on my own houses.
Don K.
EJG Homes    Renovations – New Construction – Rentals
    IMERC | Apr 14, 2008 05:05am | #1
    sounds like well drop cable...
    how far is the run????
    get an electrician.....
    WOW!!! What a Ride!
    1. DonK | Apr 14, 2008 05:42am | #2
      I just did a well replacement and I don't believe the cable that the HO has was the same as what I saw in the well, but your guess makes as much sense as anything I could think of.
      The length of the run is 100-120' by estimate. As far as the suggestion to get an electrician, I've already made that one to him.
      Don K.
      EJG Homes     Renovations - New Construction - Rentals
        IMERC | Apr 14, 2008 05:51am | #3
        was there a yellow conductor in that flat wire???
        1. DonK | Apr 14, 2008 02:44pm | #6
          IMERC - I did not see any yellow when I looked at it.
          Don K.
            IMERC | Apr 14, 2008 02:47pm | #7
            like Bill says....
            12/3WG UF....
  2. peteshlagor | Apr 14, 2008 06:31am | #4
    While you're waiting for the sparky, dig a nice trench and run a 1" plastic conduit from the source to the pond area.
    BillHartmann | Apr 14, 2008 07:23am | #5
    Gray, UV resistant, Flat, makes it sound like UF cable, Under Ground feeder.
    Look at the markings clearly. Typcially they are embossed and not printed so they are hard to see.
    But based on what you say I probably has UF 12-3 plus a bunch of other stuff on it.
    It is designed for direct burial.
    But you can put in in a conduit, but you don't want to.
    By code it is treated as a single "wire" with a diameter equal to the width of the cable.
    Then need to go through the conduit fill calculation. Would not be surprised that you need 1 1/4 or 1 1/2" conduit.
    And if it is UF, unlike NM, the sheahting encases the wire in the plastic (no paper separater) and that makes it very stiff and it would be hard to pull that distance.
    Either direct bury it or use conduit and pull wires.
    1. DonK | Apr 14, 2008 02:51pm | #8
      Bill -
      Thx for the response. You are right about it being stiff. I didn't mess with it much, but it seemed pretty hard. Same thing with the lack of paper - I didn't really notice any of it in the cable. But if it's underground, why would it be UV resistant?
      I'll have another look at the embossing, maybe take a pencil or such to try to hilight it.What other kinds of (small) grey cable are there? I'll likely be back on here tonight.
      In the meantime, I suspect that I'll be moving a shovel and laying out a trench. Then again, I do have a helper...
      Don K.
      EJG Homes     Reovations - New Construction - Rentals
        BillHartmann | Apr 15, 2008 02:37am | #9
        UF is not restricted to unground usage. UV resistant is an option, but i suspect that most are. And if it is UV resistant it can be used exposed on the outside.Here are the allowed usages"Type UF cable shall be permitted as follows:
        (1) For use underground, including direct burial in the earth. For underground
        requirements, see 300.5.
        (2) As single-conductor cables. Where installed as single-conductor cables, all
        conductors of the feeder grounded conductor or branch circuit, including the
        grounded conductor and equipment grounding conductor, if any, shall be installed
        in accordance with 300.3.
        (3) For wiring in wet, dry, or corrosive locations under the recognized wiring
        methods of this Code.
        (4) Installed as nonmetallic-sheathed cable. Where so installed, the installation and
        conductor requirements shall comply with Parts II and III of Article 334 and shall
        be of the multiconductor type.
        Where UF cable is installed as nonmetallic-sheathed cable, the ampacity of Type UF
        cable is determined according to 334.80. For Type UF cable used for interior wiring,
        see the installation requirements and the associated commentary in Parts I and II of
        Article 334.
        (5) For solar photovoltaic systems in accordance with 690.31.
        (6) As single-conductor cables as the nonheating leads for heating cables as provided
        in 424.43.
        (7) Supported by cable trays. Type UF cable supported by cable trays shall be of the
        multiconductor type.And where it can't be used."340.12 Uses Not Permitted
        Type UF cable shall not be used as follows:
        (1) As service-entrance cable
        (2) In commercial garages
        (3) In theaters and similar locations
        (4) In motion picture studios
        (5) In storage battery rooms
        (6) In hoistways or on elevators or escalators
        (7) In hazardous (classified) locations
        (8) Embedded in poured cement, concrete, or aggregate, except where embedded in
        plaster as nonheating leads where permitted in 424.43
        (9) Where exposed to direct rays of the sun, unless identified as sunlight resistant
        (10) Where subject to physical damage
        (11) As overhead cable, except where installed as messenger-supported wiring in
        accordance with Part II of Article 396
        Type UF cable suitable for exposure to the direct rays of the sun is indicated by tag
        marking and marking on the cable surface with the designation ``Sunlight Resistant.''
        This physical protection requirement ensures that Type UF cable, as it emerges from
        underground, is protected from physical damage."Now there maybe something in the UL listing that defines the sheathing color, but I doubt it.More likely the the additives that make it sunlight resistant..
Mortar for Old Masonry
