Type of wood for wooden lintel
housenut1 | Posted in Construction Techniques on September 9, 2010 10:38am
Have to replace some rotted wooden lintels on our 80+ year home.  What type of wood is recommended for these 4×6,s?  Would a treated 4×6 due the trick?
Wayne
  1. Clewless1 | Sep 11, 2010 11:28am | #1
    Lintels? Where? E.g. over doors and windows? Need to be a bit more descriptive about what you are talking about.
    1. housenut1 | Sep 13, 2010 08:16am | #7
      wooden lintels
      They are going over a five foot span of window and a three foot span of window,  The ones in there now are 3x6.  I think I'll use #1 grade douglas fir.
  2. DanH | Sep 11, 2010 12:54pm | #2
    And are they set into stone or brick, or just into wood framing?
    1. housenut1 | Sep 13, 2010 08:18am | #8
      wooden lintels
      Hi Dan:
      They are set into common brick and are 3x6.  I think I will use #1 grade douglas fir.
      Wayne
  3. k1c | Sep 11, 2010 07:32pm | #3
    lintel
    Pressure treated wood shrinks a lot.  I would not use it to substitute a structural material.  Hope it helps.
    1. housenut1 | Sep 13, 2010 08:20am | #9
      wooden lintel
      Thanks for the tip it's good to know.
      Wayne
  4. calvin | Sep 11, 2010 07:43pm | #4
    Simple answer
    2-2x6's.
    1. housenut1 | Sep 13, 2010 08:23am | #11
      wooden lintel
      I may do that with #1 grade douglas fir.
      Thanks,
      Wayne
    2. Clewless1 | Sep 13, 2010 08:23am | #12
      I agree w/ Calvin - long span 2 - 2x6 ... but the short span should be able to use a single 2x6. Lighter and cheaper and easier to work with than e.g. 4x6. I did a bunch of load bearing 30-32" window headers with a single 2x6 ... BI OK'd it.
      We are assuming this is a load bearing wall condition, right?
  5. CooperDBM | Sep 12, 2010 11:03pm | #5
    I agree with Calvin on using 2x6 or 2x8 to avoid splitting.  I'd use PT but in any case put a moisture barrier under them so that water can't wick up from the foundation wall.
    1. calvin | Sep 13, 2010 05:41am | #6
      I'm still not sure........
      Where these wood members are going.
    2. Clewless1 | Sep 13, 2010 08:20am | #10
      Never heard of moisture wicking up through the jack/king studs to the lintel.
      1. CooperDBM | Sep 13, 2010 08:24am | #14
        I'm assuming we're talking
        I was assuming we're talking about the sill plate on top of the foundation.  Didn't read the original post correctly.
      2. DanH | Sep 13, 2010 08:31pm | #15
        That's why we wanted to know if they were set into masonry.
    3. housenut1 | Sep 13, 2010 08:24am | #13
      wooden lintel
      Thanks for the reply.
      Wayne
Outdoor Lighting
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
