I will be starting the framing for a new house which will have real stucco exterior. The plaster guys want the tyvek underneath the plywood sheathing, saying that the plaster will adhere better to the bare plywood. I remember hearing about something like this years ago when tyvek first came around but I cant remember the whys and whatfors so, what is the proper way to go about this??? Am I asking for trouble doing it their way? Thanks Petey
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
Use metal lath over tarpaper. You need a moisture barrier between the wood and cement.nail the lath down good. Thats what hold your stucco on the wall.
I second the felt and lath method. Who is this stucco guy anyhow, telling you he wants to put it directly onto the plywood? Are we really talking about a portland cement stucco job here, or an EIFS synthetic?
Real stucco needs diamond lath mesh, goes on in three coats, and builds out to a little under 1" total thickness. When done right, it goes on over felt, so as to be isolated from the sheathing.
If you are in some insanely dry end of the continent... why not?
Turtleneck
the only miracles I've ever produced are waiting for me at home
Yes this is a real stucco job (with portland cement) , It is in the Chicago suburbs. One other note; the house that is going to be torn down to make way for this new one is about 75 to 80 years old. It has cypress 1x4 sheathing with dovetailed grooves to hold the plaster, no felt or mesh!
Tyvek has a product called stucco wrap, and all tyvek thak I know of goes outside of the plywood. Stucco wrap is textured, so I imagine it holds the stucco better. However, the idea behind the tyvek is that it repels moisuture from penetrating the wood sheathing from the outside but it allows moisture to escape from the inside to the outside, should there be condensation behind the plywood.
For traditional stucco applications, see your stucco supplier. I went to Durock and they had technical papers available that show how to do the job. The felt and lathe method is commonly used, though they also have Tyvek in place of the felt. The metal lathe needs to be applied using furring nails, which keep the lathe slightly away from the paper (I can't remember the gap required. Also, pay attention to the metal lathe: you will notice the pattern has an angle to it. That angle should be sloped upward from the back to the front so that when stucco is applied, it "drops into" the lathe rather than fall away from it.
I'm not a stucco guy and this is based on my recent research as I considered stucco on two gables that I have. Advice came from Durock makers of stucco products, and two independant contractors. I have also been told that nailing the stuff on tight reduces cracking, though I don't know for sure.
Out here in California, we have stucco lathe, which is a two part sandwich made of felt and chicken wire in 8x4 sheets which replaces house wrap and gets nailed to the plywood. It even has weep holes. The stucco sticks to the wire. You could put housewrap under it, and stucco would never touch it. I don't get the question, really. Use the stucco wrap.
Regards,
Boris
"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
I guess the question was if anyone had ever heard of putting tyvek under the sheathing. Thats how the plasterer (? spelling) wanted his surface for the stucco application. I am just doing the carpentry and my concern was being responsible for any complications due to lack of moisture barrier. thanks for the info
My first thought on the subject was no way. Stucco wicks water. Maybe those solid boards would stand up to some moisture but I thought plywood will eventually fail and separate. With Tyvek behind the plywood it can only dry from one side. But then again, maybe your stucco guy knows what he is talking about and we'll both be dead and long gone before there is a problem.
Trying to get dried concrete off of a sheet of pl;ywood is next to impossible and mabe the rough surface would double the surface area and speed drying.
I guess you have to look at things from all sides.
I still prefer tarpaper to Tyvek for breathability
Turtleneck
I feel the same way about the tarpaper and isn't it organic? thanks for the feedback
I hope this doesn't get out, but
I think alot of suspect products
[ (like Tyvek) ]
have been successfully marketed.
(right click space above) Turtleneck
I have seen old houses with stucco over wood lath. It held up with no visible problems, but it was one story with 4' eaves too.
As I understand it, stucco should never actually contact the housewrap or tarpaper. That includes Tyvek Stucco wrap. Contact can allow water to pass through the housewrap or tarpaper by capillary action.
BTW, seems to me that stuccoing right over plywood is inviting rot. I'd sheathe, then do a double layer of tarpaper applied shingle style, #30 is better, then wood lath covered by expanded metal lath followed by stucco. The reason for the double layer is that if the top layer is compromised by stucco contact, the bottom layer should still keep moisture away from the sheathing. Next best would be to skip the wood lath, but I wouldn't leave out anything else. I might use housewrap instead of tarpaper, but only if the 9 ft. rolls saved enough labor to justify the extra cost. And if I used housewrap, I don't think I'd skip the wood lath, because I'd be too concerned about stucco contacting the housewrap.
Check our http://www.buildingscience.com for more on this topic. Andy Engel, The Former Accidental Moderator
