Tyvek Drainwrap 2x price of Tyvek Homewrap
Kevin_D | Posted in Construction Techniques on March 7, 2011 12:30pm
Hi Guys,
     I have a quick question. I was going to use Tyvek Drainwrap on my project http://www2.dupont.com/Tyvek_Weatherization/en_US/products/residential/resi_drainwrap.html
The problem is that only sources I’ve been able to find charge literally double the price of normal Tyvek.
I mean I could literally put up two layers of the regular Homewrap for the same price. http://www2.dupont.com/Tyvek_Weatherization/en_US/products/residential/resi_homewrap.html
I’ve reviewed the Fine Homebuilding article about using furring strips https://www.finehomebuilding.com/how-to/articles/siding-with-rain-screen-walls.aspx?ac=fp
Do you guys have any experience with Drainwrap? What do you think?
  1. BetterYet | Mar 07, 2011 01:32pm | #1
    What is the rest of the system?
    Can you tell us the rest of the wall assembly? wood frame / sheeting / exterior siding?
    depending on your exterior surface and your local building codes, you may want or need to use a drainage plane behind that surface. If so, the drainwrap may be good value as compared to typical tyvec and a strapping detail.
    The basic logic is that the tyvec prevents moisture from passing into the wall, but because it is a flat sheet surface, it also holds the moisture against the exterior surface using capillary force. If that exterior surface is know to have problems with prolonged moisture contact, then a drainage plane is an important addition. By adding a drainage cavity, we remove the majority of contact between the two surfaces, and allow moisture to evaporate or drain down and out. The drainwrap is a single product that accomplishes this. and is simpler to install than many other rain-screens.
    Be sure and check with typar as to the acceptable exterior claddings for the product, as well as the window and door flashing details.
    Hope that helps. Cheers!
  2. bob@stucoflex | Mar 16, 2011 07:10pm | #2
    RE: Tyvek Drainwrap
    Instead of Tyvek Drain Wrap you could also think about applying a Waterway Drainage mat to your exterior and just use building paper or the WWplus thats already attached to Typar.  It may be a little more expensive but you will create an actual drainage plain and a real path for the water to escape.  Take a look, http://www.stucoflex.com/rainscreen_drainage_mats.htm
Beat the Heat: Cool Innovations
In this time of weather extremes and power disruptions, it's important to learn from the past as we think about the future.
