I have a section of wall in the front of my house, 2×6 construction, r-19 insulation, tyvek and stucco on the outside. On the inside of the wall, should I use plastic sheeting or a layer of tyvek to further stem any drafts through the wall?
Tyvek is not a VB.
Which you use depends on much of the other detqails of your climate, insulation type, and the rest of how the house is built.
I note you are in Philly -- my condolences! ; - )
As the topic of your post implies, you need a vapor barrier on the inside of your walls. Tyvek does not a vapor barrier make. To the contrary, Tyvek is designed to allow water vapor to pass through. I'd suggest you use 6 mil poly, caulked at the margins and taped at the seams.
Mike Hennessy
Pittsburgh, PA
Then, thats what it shall be! Thanks, I was pretty sure, but a quick post would confirm my thinking.
Hey.....no Philly bashing!!!
At least we've won a........ shoot.
Well at least OUR mayor.......shoot..
At least we get less snow!!!
Well at least Frank Rizzo isn't around any more. (Is he?)
I think we have a Frank Rizzo Jr floating around.
Floating in the Schuylkill would be ideal.
No obvious reason to not use plastic. Tyvek will work about as well to stem additional air infiltration, but is not a vapor barrier (as others have said).
My take, though, is that in Philly you **probably** don't NEED an additional vapor barrier, especially if the fiberglass is faced. Won't do any harm, though.
" you **probably** don't NEED an additional vapor barrier, especially if the fiberglass is faced. Won't do any harm, though. "
Well, not attempting to contentious or anything but there is always the possibility of inadvertently constructing a double vapor barrier by placing poly on top of the FG batt impregnated facing if that facing doesn't receive diagonal slash cuts a couple inches apart prior to the placement of the poly.
be for what it's worth
every court needs a jester
Two adjacent vapor barriers will not do any harm, especially if the outer one (in cold climates) is "weaker" (as is true of FG facing vs plastic sheeting).It's not "double" vapor barriers that causes trouble, it's having a vapor barrier on the cold side.
Must be I'm still living in the '80s.
And all this time people been accusing me of still being in the '70s
Are you allowed (by code) to use tyvek behind stucco in PA? They don't allow it in MN.
Tyvek makes a Stuccowrap for that purpose.
