Tyvek over black fiberboard sheathing?
OZ_Repair | Posted in General Discussion on June 22, 2015 05:37am
Our contractor will remove several rows of vinyl siding above the entrance door for some repair. However not all the way up to the roof, some siding rows will not be removed. Only about 1/2 of the rows will be removed.
He recommended to install Tyvek where the hosue sheating is exposed.
The house sheeting material is blackboard. Tyvek’s edges would have to be taped the the blackboard.
1) Will Tyvek tape stick to the blackboard?
2) Should he use instead some wider windows self-adhesive flashing tape?
3) Will the blackboard contaminate Tyvek and hence making it to fail?
4) Should he use #15 or #30 tar paper instead of Tyvek?
Thank you.
  1. DanH | Jun 22, 2015 06:30pm | #1
    It depends on the tape -- it might be better to use nice gooey flashing tape rather than Tyvek "sheathing" tape, as the latter will not stick that well to the beaverboard.  And the tape edge should be stapled to the beaverboard to assure it will remain attached.
    The beaverboard won't hurt the Tyvek, and tar paper will work no better than Tyvek.
  2. oldhand | Jun 22, 2015 06:48pm | #2
    interesting question
    Mostly the black part of blackboard is asphalt. Some types have more asphalt than others. I would expect that tyvek will work over most if not all types but I know for sure 15# felt will.
    The tyvek tape would probably not work at all, the self adhesive flashing tape maybe would stick to blackboard.
    I wouldn't worry a whole lot about it if you don't have leakage issues already. Blackboard isn't structurally all that great but isn't a slacker about getting wet.
