Tyvek … Typar … Premium wrap … tapes … flashing … HELP!
xtal_01 | Posted in Construction Techniques on July 28, 2020 01:16pm
OK … so you guys have guided me along so far.
3500 sq ft shop … 3 x 6 construction … CDX plywood sheeting … house wrap … 3/4″ strapping for a drain plane … LP smart side board and batten (16″ x 16′ pieces).
I am just doing the final take off to get the material order in.
I thought house wrap would be the easiest part … hmmmmm.
I have watched countless videos  … read a bunch of posts … called the local suppliers ….
On my last house I used a woven product.  Now I am told this is junk.
I was going to go with the old standard Tyvek   … then one person says use Typar to hold out the water better … but another says it will rot, use Tyvek so it can beath.
I give, what house wrap should I use ?????
Also, with 16 ft walls, I need at least two piece.  The video I just watched showed them taping the seam between the two.  Is that correct or do I leave them open so water can drain if it get in ?
Same for the bottom … open or taped  (I see windows are to be left open under them) ????
Finally, tape … what brand … Tyvek .. Typar …. ?????
Opps … last one … flashing (wide tape for around windows, sill area, ….).  My last builder just used left over “Grace water and ice” from the roof … I think he may have even used some shingles when that ran out.
I see there is a Typar “Flashing Flex Roll” … seems you don’t have to cut it at the bottom of the window sill.
Is this best or ?????
As always, any advice will be greatly appreciated!
Mike
  1. xtal_01 | Jul 28, 2020 06:57pm | #1
    Just to throw a monkey wrench into the problem ... I just got an e-mail from a friend saying to use good old tar paper rather than Tyvek ....
    Even more confused ...
    Thanks .... Mike
  2. Frankie | Jul 29, 2020 02:55pm | #2
    Tyvek has a higher perm rating than Typar (56 vs 7) and has a drainage plane. House stays drier and if wet, dries faster.
    https://barricadebp.com/news/comparing-home-construction-house-wraps-typar-vs-tyvek
    Use Grace Vycor as your flashing tape.
    https://gcpat.com/en/solutions/products/vycor-weather-barrier-flashing-tapes/vycor-plus
    Frankie
  3. Vishnej | Jul 29, 2020 03:22pm | #3
    Most of these are usable. Some are more fragile than others - asphalted building paper/felt was replaced with tyvek/typar, and then a wide range of other products have come on since then. Some are more moisture-sensitive or less UV-stable than others.
    https://www.youtube.com/watch?v=24ugqWbHRT8
    What seems to be universally recommended these days is a vented rainscreen ("drain plane") overtop the WRB - in every situation, in every climate it makes the WRB and the sheathing and the siding dry orders of magnitude faster, with no downsides but a slight increase in installation complexity. Quite possibly this renders all of the options acceptable.
  4. xtal_01 | Jul 29, 2020 04:51pm | #4
    Awesome ....
    I have definitely decided to leave a 3/4" drain plane ... something I have never done before.
    Since the LP siding is ... well at least in my mind ... just fancy osb, I think this should help keep everything dry.
    With some luck, the house wrap will never see any moisture since it will need to get by the siding then jump a 3/4" gap but just in case, I am trying to use what ever is "best" ... though I am finding "best" can mean a lot of things.
    Thanks ... Mike
Beat the Heat: Cool Innovations
In this time of weather extremes and power disruptions, it's important to learn from the past as we think about the future.
