Recommend me a material and technique, please. We are installing warm water tubing under wood frame subfloors, 1-3/4 x 9 1/2 I-joists, 16″ centers. I need a foil faced insulation with foil facing upward to create an insulated cavity. What have you used, and how did you install, to insulate this space?
With the right approach, you can restore old hardware—whether through soaking, scrubbing, or polishing—giving it a fresh look while preserving its original charm.
Recommend me a material and technique, please. We are installing warm water tubing under wood frame subfloors, 1-3/4 x 9 1/2 I-joists, 16" centers. I need a foil faced insulation with foil facing upward to create an insulated cavity. What have you used, and how did you install, to insulate this space?
