under mount sink caulking
ronf | Posted in Construction Techniques on February 28, 2008 05:30am
I wish to mount a Stainless under mount sink to a laminated white oak counter top (1″ thick”). The sink manufacture (Franke) supplied silicone caulk as the sealant. Should I put shims between the top and sink when first clamping the uncured caulk then remove them when cured and clamp tight? The idea is to keep a thin gasket of caulk to allow a compliant seal.
  1. plumbbill | Feb 28, 2008 05:39am | #1
    Are you going to put a "perfect" bead of silicon around the top that is thin enough so it doesn't bend the stainless when clamping?
    Usually we put a generous amount of caulk on the lip then clamp or secure the brackets & force the caulking into all uneven spaces of the two surfaces then clean up the "squeeze out".
    “The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
