under mount slides – super heavy duty?
marklamberti | Posted in Construction Techniques on January 29, 2016 10:00am
I did my kitchen 3 years ago with some semi custom cabinets.
It has a peninsula with a 30 drawers with full extension undermount slides.  We keep our pots and pans in this drawer.
The slides are starting to sag a hair.  I am thinking i want to replace them with a higher end set of slides.  I think the current ones are rated at 100 lbs.
Any recomendations for slides?  I cant seem to find any with a higher then 100 lb rating.
thanks
mark
    deadnuts | Jan 29, 2016 09:00pm | #1
    100 lbs of pots and pans in any one full extension drawer is hard to believe. And you have 30? Can't you split these loads up a bit? Remember, slides have a load rating which is generally conservative of actual capacity.
    At any rate, I've found good selection of heavy duty hardware here: https://www.cshardware.com/ and also Hafele.com
  2. jimmiem | Jan 29, 2016 09:34pm | #2
    Drawer Slides
    I've had good luck with Knap & Vogt slides.  I've got a couple of drawers that are 28" wide and loaded with canned food are in excellent working order.
  3. calvin | Jan 29, 2016 10:17pm | #3
    Mark
    Please clarify this-----you have a 30 inch drawer that the slides sag.  Wore out?
    even with cast iron cookware, it shouldn't have.  Contact the manufacturer and see if they're gracious or pricks.
  4. marklamberti | Jan 30, 2016 07:35am | #4
    Sorry the drawers are 30"
    Sorry the drawers are 30" wide is what i meant i should of proof read my initial post.
    I will reach out the cabintie manufacturer and see how responsive they are.  Assuming they are not to helpful keep the recomendations coming.
    thanks
    mark
  5. DanH | Jan 30, 2016 08:12am | #5
    When our kitchen was redone 6-7 years ago the guy installed sliding shelves in the lower cabinets.  He didn't use undermount slides (no need, and nothing to mount them on), but side-mount units (with a lip under the edge) which attached to a plastic vertical rail, as some sort of "system".  The shelves were custom-made to fit. We're very pleased with them.
  6. gfretwell | Jan 31, 2016 12:44pm | #6
    Double them up. I have a gun cabinet that slides back into the wall and it is hanging on four 100# slides
