Under sink Water filter recommendations
martingale | Posted in General Discussion on December 27, 2023 10:24pm
We use public  water and sewer and water taste is ok. But we recently tasted the tap water from a friend’s in FL and they used a big tank(sediment I think)  +  a few of staged filter system, their water taste is the best wr ever had our of any tap water , there is a slight sweet flavor from it. So if we want to install a under sink filter system, we dont need that big water tank for sediment I think, but just a few staged filter and we will have that sweet flavor? Any brand to recommend?
  1. ativadorebrasil | Dec 28, 2023 03:14am | #1
    It's great that you enjoyed your friend's filtered water in Florida. While replicating the exact taste might be challenging, achieving significant improvement and potentially a hint of sweetness is definitely possible with an under-sink system.
    unclemike42 | Dec 28, 2023 11:59am | #2
    You want to make sure the sweet taste is not from lead or another thing you really do not want in your water.
    A good start is a water test to see what is in your water you want to get rid of.
  3. davidmarsh3193 | Jan 10, 2024 10:33pm | #3
    Certainly! Here are some real-life suggestions for improving the taste of tap water using an under-sink filter system:
    Identify Water Issues:
    Determine the specific issues with your tap water by getting it tested. This will help you choose a filtration system that addresses the particular contaminants affecting the taste.
    Consider a Multi-Stage Filtration System:
    Opt for a multi-stage filter system that includes different types of filters, such as sediment filters, carbon filters, and possibly a reverse osmosis membrane. This can effectively target various impurities and improve taste.
    Include Carbon Filters for Taste Improvement:
    Carbon filters, especially activated carbon or carbon block filters, are known for improving taste by removing chlorine and other unpleasant flavors. Ensure your chosen system includes these filters.
    Install a Sediment Filter if Needed:
    While you might not need a large sediment tank, including a sediment filter in your system can help remove larger particles, contributing to clearer and better-tasting water.
    Choose Reputable Brands:
    Look for under-sink filter systems from reputable brands known for quality and reliability. Brands like Aquasana, iSpring, and APEC Water Systems have a good reputation in the market.
    Check Certification:
    Ensure that the filter system is certified by reputable organizations such as NSF or ANSI. Certification indicates that the system meets specific standards for performance and safety.
    DIY-Friendly Installation:
    If you prefer to do it yourself, choose a filter system with straightforward installation instructions. Many under-sink systems are designed for easy installation without the need for professional help.
    Regular Maintenance:
    Commit to regular maintenance as recommended by the manufacturer. This may involve replacing filters at specified intervals to ensure the continued effectiveness of the filtration system.
    Read Customer Reviews:
    Check online reviews from customers who have installed the same or similar filter systems. Real-world experiences can provide valuable insights into the performance and durability of the product.
    Budget Considerations:
    Consider your budget when selecting a filter system. There are various options available at different price points, so choose one that aligns with your budget while still meeting your water quality improvement goals.
    Consult Local Water Experts:
    If you're uncertain about your water quality or the best filtration approach, consider consulting with local water experts or professionals who can provide personalized advice based on your specific location.
    Remember, the key is to tailor your filtration system to the unique characteristics of your tap water to achieve the desired taste improvement.
  4. eddo234 | Jan 15, 2024 01:20pm | #4
    I installed an Aquasana 3 stage filter under my sink 3 years ago. It’s worked fine.
  5. mgmahan | Jan 15, 2024 02:57pm | #5
    I doubt if the tank is for sediment. Public water systems are pretty well filtered. Any reputable brand of under the sink RO system should be fine.
