Gonna put a new vinyl floor on our kitchen. Existing floor is vinyl and is smooth and in good shape.
Previously, we had vinyl installed in the hall leading to the kitchen by a local flooring dealer. 1/4″ BC ply was screwed and nailed to the subfloor. Before installing, he spread Titebond II down down on the subfloor and layed the ply on. The hall floor is now 1/4″ + higher than the kitchen floor now, and I’d like a nice transition instead of the elevation change we have now. I want to put the underlayment in myself to save bucks. Going to have the same guy do the vinyl install.
So, the question is what kind of glue would you use on top of the existing floor vinyl to glue the ply? I don’t think any PVA glue would work, and construction adhesive may be too thick and cause irregularities.
Hi Tom,
Personally I think you can just forget the glue. I've done many coverups and even on new construction, I just staple it down. And I mean staple it down a lot. Every four inches or so. We use luan underlayment. Nice smooth service. I use a senco SKS to "nail" it down. 3/16 crown and usually a 1-1/4" leg. Only thing you need to be careful of is that you are not setting the staples too deep.
Any irregularities in the edges can be taken care of with a quick pass of a belt or disc sander. And if there are any little gaps, the flooring guy will fill them if he needs too.
Luan is not accepted by vinyl mfgs anymore it will void warrantee baltic birch is the recomended product stapled 3"x3" in field and 1 1/2" on edges APM and Halex are 2 names I use they come in 4'x5' sheets I pay about $11.00 a sheet nice surface and no voids in sub plys.
Hey Gunn308,
Thanks for the info.....
Have to have a talk with the flooring guys 'bout this.
You agree that no adhesive is needed?
Never have used it, but have skim coated embossed vinyl with Webcrete 98 portland based patch and installed right over.
The floor place requires this type of underlayment for them to warranty the installation, so it doesn't look like I have a choice.
I do think that the staples sound like a good idea, so I'll run it by them.
Still no ideas on glue?
try to think about the guy who has to follow you in twenty years. a stapled underlayment is efficient and it always works. you don't need to glue it down. if you've ever had to demo an existing vinyl floor and it's underlayment, and had to spend 2-3 hours hand chiselling the chunks of glue off, you know what i mean.
ditto on the lauan. the last lauan u/l i laid was covered with the cheapest vinyl i've ever seen. there were brown spots leeching through only a couple of days after it was installed.
good luck rg
Skip the glue. Use the 1/4" underlayment birch plywood. I usually nail it off with ring-shanks, 4-6". After it's nailed down, I top it with a leveling compound to fill in the seams and hammer dents. When dry, belt sand it smooth. (A fan blowing on the surface speeds srying time.) Vinyl telegraphs any imperfections in the subfloor, so make sure your nails (or staples) are set below the surface.
I won't battle the choice of underlayment, but hand nails? Holy prepwork Batman.
And ya, no glue. Try to pull this stuff up when it is properly fastened.
I'll admit that staples would be faster. So now I'm trying to figure out why I should nail down another subfloor.
A good excuse to buy another tool. Cool.
Ya, I use a narrow crown, 7/8 or whatever is needed. I have a Bostitch, but would rather have gotten a Duofast when my first one got stolen, (they might be overkill for occasional use), but B's were all I could get, and you know the deal, I didn't have a week to wait.
I hate the Bostitch, but it can work, and the prep is zip. The speed is to die for installing, new tool is right. What, maybe $100ish?
That's the reason for staples no rosettes, just make sure they're divergent points.
Got to admit I've never used staples before because I never bought a staple gun. (I assume you're using something larger than 1/4", right?) It (staple gun) would definitely be faster. But even with staples, I'd cover with a leveler.
1/4" crown is the standard 7/8"-1 1/4" lengths and DouFast lasts the longest for day in day out use. Divergent points are; one leg is chiseled in the opposite direction from the other leg so when the staple goes in the legs go in opposite directions. The heads are small enough that you only have to patch and sand your seams.
And while I'm thinking about it, which stapler do you recommend?
What is a divergen point?
I believe it means the points of the staples are cut with opposing bevels, so when the staple enters the wood, the two points splay out in opposite directions, creating a tight joint that is a bear to pull up. Think of the points as legs doing the splits and you get the idea.
If I got it right, that is.
I use 1.5" narrow crown staples in a 4" grid in the field (center of sheet) and 2" on the edges, but if you decide to hand nail, be sure to use underlayment nails. They are a little different than RS common, etc, more like a box nail, and the last thing you want is nail pops in the middle of your vinyl floor from using the wrong nails.Matt
