undermount black sink w/laminate
junkhound | Posted in Construction Techniques on January 19, 2009 10:37am
First, dont say ‘dont try it’, as i gonna. <G>
Anyway, anyone done this.
.. plan is to first build up some 3/4″ thick black nylon 66 to marine grade baltic birch plywood, undermount sink epoxied to nylon, laminate edge over the nylon with epoxy (regular contact cement on the wood) and then route the nylon to match.
Sny suggestions other than nylon/  could use corian if could find some cheap chunks.
  1. rez | Jan 28, 2009 05:03am | #1
    Greetings junkhound,
    As a first time poster Welcome to Breaktime.snorK*
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    94969.19  In the beginning there was Breaktime...
    94969.1  Photo Gallery Table of Contents
      Ted W. | Jan 28, 2009 05:07am | #2
      Uhhh... Rez.
      I think the warm welcome is a little late. Junkhound has over 5000 posts. ;-)~ Ted W ~
      Cheap Tools - BuildersTools.netSee my work - TedsCarpentry.com
      1. rez | Jan 28, 2009 05:32am | #3
        man, r u shiddin' me???
        seeyou invented shid
        Edited 1/27/2009 9:33 pm ET by rez
          Ted W. | Jan 28, 2009 06:02am | #5
          Why do I get the feeling I'm missing something? ~ Ted W ~
          1. rez | Jan 28, 2009 06:28am | #7
            Feelings.
            Nothin' more than...
            Feelings.
            Ted W. | Jan 28, 2009 06:41am | #8
            I want some of whatever you have. >g<~ Ted W ~
    2. joeh | Jan 28, 2009 06:52am | #9
      Think this is a first though.
      First time he ever asked a question that I can remember.
      Joe H
      1. rez | Jan 28, 2009 07:02am | #10
        I found one other before that was laying there unanswered.
        Probably most are wondering what they could suggest to him that he hasn't already tried.
    Ted W. | Jan 28, 2009 06:00am | #4
    Any suggestions other than nylon...
    High density polyethylene.
    ~ Ted W ~
  3. paulbny | Jan 28, 2009 06:20am | #6
    Junkhound,
    Karran Products makes a sink for this but more importantly the have a proven technique that looks like it would work for most sinks.  Here's a link.
    http://www.karranproducts.com/installation.html
  4. wallyo | Jan 28, 2009 08:43am | #11
    Junkhound
    Did it on my own bath except the inside edge above the sink bowl is laminate and the top is laminate. I cut the oval for the sink then cut a strip of laminate the exact diameter. I used epoxy to glue the strip in the opening sanded it flush put the laminate on top. Sealed the bottom surface with an exterior poly, caulked the sink rim and used the clips that came with the sink to hold it on.
    Wallyo
    1. wallyo | Jan 28, 2009 08:45am | #12
      Sorry the photo did not take on the last post.
