Underside of Pier and Beam framing
jimAKAblue | Posted in Construction Techniques on March 25, 2009 08:35am
Anyone got any good (and cheap) methods for sealing the underside of a pier and beam shed?
The shed will be condidtioned so I will be insulating the floor. I was thinking of adding a layer of foam on the bottom but then wondered if the critters like chomping on it.
I’m only going to be 8″ off the grade and I didn’t plan on using any treated lumber. I hate that stuff…it’s all laced with poison.
  1. jimAKAblue | Mar 25, 2009 10:24pm | #1
    Shameless bump
      Dam_inspector | Mar 25, 2009 10:29pm | #2
      What about some cdx sheathing? As long as air circulates under the shed I believe it won't rot. Even flakeboard is probably OK.
      1. jimAKAblue | Mar 25, 2009 11:17pm | #3
        Air will be circulating under it freely. I plan on adding some screening so critters  (and bums) can't camp out under there.
  2. dovetail97128 | Mar 25, 2009 11:21pm | #4
    CDX ...used to do that as the fix when building pole houses.
    "Soffit Board" also would work.
    1. jimAKAblue | Mar 25, 2009 11:54pm | #5
      I considered exterior soffit ply. The 3/8 is light and fast....and unfortunatly expensive.
      I think I'll just paint some osb and hope it survives 5 years or so.
      1. AitchKay | Mar 26, 2009 03:58pm | #7
        Speaking of expensive, 1/2" Azek ply would last forever. But at $100 a sheet...How about metal or fiberglass pole-barn roofing? You really want something impervious to the elements, I'd think.AitchKay
  3. Hiker | Mar 26, 2009 02:58pm | #6
    Jim,
    There is a guy on craigslist austin selling a couple units of Tiger foam-may do the trick
    Bruce
