unglue pvc
rich2 | Posted in Construction Techniques on April 11, 2005 05:55am
 Does anyone know if there is a way to unglue pvc sch.40 drain pipe. I have a leak coming out of a 90 degree street elbow?  Thanks in advance.
  1. danski0224 | Apr 11, 2005 06:51am | #1
    Nope. The glue bonds the two pieces together chemically by melting them together. Sometimes it is possible to cut the hub of a fitting and chip off the pieces, sand and reglue.
  2. DaveRicheson | Apr 11, 2005 11:51am | #2
    Cut it out and replace it, is the best fix.
    That said, I have had luck with heating the fitting with a heat gun, and slopping on more glue. The hot fitting will suck enough glue into it seal a small leak.
    Give it a try. It could save you some work.
    BTW the fitting must be dry  when you try the heat/glue solution.
    If it doesn't work. Get out the saw for plan A
    Dave
  3. IronHelix | Apr 11, 2005 12:47pm | #3
    They make a clay like epoxy plumbers putty by Duro...two part different collors in a bubble pack.  Twist and roll putty  together till the colors are blended, clean the joint that is seeping, blow dryer to take away moisture, roll the epoxy in a rope shape and compress into the glue line.
    Recently they have added a fast set (within an hour or less) as well as the original formula(6-12 hours?)  Works on steel pipe also!
    I have one such patch on my hot water plumbing line since 1973!
    Sold many packages of the stuff to my customers of 30 years when I was in business.
    Also a brand labeled "P-57"!
    ..............Iron Helix
