We may have the opportunity to build a very unique multi-function building. There is a design element which is causing some headaches on our end, maybe you guys can help. We need a source for cedar shingles which are machine cut. They need to be a uniform 8″ wide, 24″ long, and tapered from 3/4″ to nothing. Cedar shakes are to random in width and a synthetic product won’t match our specs. Any ideas… we can be reached directly at 620-663-6200 or [email protected].
Thanks in advance,
JVB
I've used shingles from Teal Products and have been very happy with the uniformity of their product.
http://www.tealjones.com/index.php?site=9
I suggest contacting them (or some other shingle manufacturer) and asking them if they can make you a custom product.
Hello, this sounds lioke a unique job.
If I had such a requirement, I would contact some local cedar mills for a quote. I am in Miane where this is possible. What is your location?
Try these guys;
http://www.builddirect.com/Cedar-Shake-Shingle.aspx
Good Luck
Kevin
The first call I'd make is to the architect, ask where the shingles can be obtained. If they're going to issue that strict of a specification on the product, then there's one of two things going on:
1. They already had a manufacturer and/or supplier in mind, or:
2. Somebody is a moron.
If 2. is the case, it's very likely a custom job and will be big $$$ and probably big lead time, depending on the quantity. Actually it's probably true either way.
in the northeast, i'd give Liberty Cedar a call.....
another good source would be Beacon SupplyMike Smith Rhode Island : Design / Build / Repair / Restore
MikeSort of a highjack here, do you have #'s for those guys?
Kevin
i'm in NC for Thanksgiving
but you can google on Liberty Cedar
http://www.libertycedar.com/Customer_Service.htm
and Beacon Supply..
http://www.beaconroofingsupply.com/
both are excellents sources of red cedar, white cedar , etc
Edited 11/20/2006 11:54 pm ET by MikeSmith
Edited 11/20/2006 11:56 pm ET by MikeSmith
thanks
enjoy t-day
kevin
Thanks for the links. Let you know what gets turned up. Have a great Thanksgiving!Thanks,
JVB
