Unique uses for peel and stick flashing
| Posted in General Discussion on November 30, 2006 06:41am
Hello All-
Does anyone have some unique uses for peel and stick flashing? At my job, we have found that it works great for patching holes in a tarp. Wipe the area off with a towel first, and press it on really hard. It seals pretty well. Any others?
  1. xosder11 | Nov 30, 2006 06:43pm | #1
    You know that new guy that wont shut up, you can tape their mouth shut pretty good with it.
    Edited 11/30/2006 10:45 am ET by xosder11
      IMERC | Nov 30, 2006 07:21pm | #3
      you fire the duct tape??
      1. Jmadsen | Nov 30, 2006 07:28pm | #4
        The roll of duct tape is still king, but I'm teaching a class on proper window and door installation with the help of our local Vycor rep. Has anyone ever used duct tape to wrap a window? I don't know, I bet it would work in a pinch. Probably not too legit for warranty, though.
          BillHartmann | Nov 30, 2006 07:45pm | #7
          Duct tape would make a lousy window flashing.The adhesive will dry out and it will let loose within a year.
        2. paulbny | Nov 30, 2006 08:35pm | #9
          Used some of that Gorilla Brand Tape once to wrap a window.  Last window on the job and out of regular sealing tape.  Worked great, until we figured out that the window was 1" low.  I was actually worried we were going to tear the nailing flanges off the window trying to take the tape off.  Regular duck tape probably would work though.
          1. ANDYSZ2 | Nov 30, 2006 09:07pm | #10
            It sucks as a weather proofing have tried foil tape too next day its peeling back off the wood.
            Even peel and stick will peel off I am interested in some product that you can put on take a heat gun too and in 5 minutes there is a permanent solution.
            REMODELER/PUNCHOUT SPECIALIST
          2. jesse | Nov 30, 2006 09:14pm | #11
            Are you kidding? Any ice and water shield type product becomes one with the substrate if you heat it up.Just try peeling up some on a roof in the summer.
          3. dovetail97128 | Nov 30, 2006 10:05pm | #14
            I repaired a plastic kayak that was seriously fractured with torch down roofing. The manufacturer said the kayak was unrepairable, nothing would stick to the plastic.
            I roughed up the surface, cleaned it well with alcohol and heated the boat until it was warm , then applied a very low melt temp. torch down product inside and out, used a heat gun for the heat source. Twelve yrs ago and the patch still is water proof.. look like he** but the kids don't mind.
          4. ponytl | Dec 02, 2006 06:15am | #36
            don't know where you'd find it...  but i had some military spec  tape made by Raychem... the people who invented heat shrink tubing and the equipment to produce it...
            the tape once applied and lapped or wrapped onto itself became one...  some really impressive stuff.... i tried to test it's limits &  never found em...
            p
          5. johng45 | Dec 27, 2006 09:02pm | #50
            Is this the same stuff?
            http://www.duluthtrading.com/store/department/sale/sale2/sale_viewall/42042.aspx?feature=Product_156
          6. ponytl | Dec 28, 2006 02:23am | #51
            looks like it....  i had/have some samples from when we were a raychem distributor to the military... kinda saved it for when i really needed it... but that looks like the stuff...
            p
  2. xosder11 | Nov 30, 2006 06:44pm | #2
    Back hair removal.
  3. Billy | Nov 30, 2006 07:36pm | #5
    Waterproof your boots.  Patch kids pool.  Turn a cardboard box into a stealth jobsite ice chest on Friday afternoon.
    Don't use it for birth control though -- removing it is hell.
    Billy
    1. Jmadsen | Nov 30, 2006 07:42pm | #6
      I think the stealth cooler is the best so far!!! LMAO on the birth control idea!
  4. joeh | Nov 30, 2006 08:08pm | #8
    Plumbers crack control.
    Joe H
    1. merlvern | Nov 30, 2006 09:48pm | #13
      gorilla glue works for that too!
  5. rasconc | Nov 30, 2006 09:14pm | #12
    I was in the local Habitat Store (Asheville, NC) yesterday and they had rolls probably 6-7" x 6-7" for $5, wish I had grabbed a couple.  Had Simpson hangers out the azz for next to giveaway price.  Non Zmax but fine for interior applications.  Got a boy or the 2x4 saddle repair plates 50 for $20.  Got a big bix of the stair tread brackets for $20.  Had some serious stuff for big beams.
    Luka | Nov 30, 2006 10:29pm | #15
    Ok, here's an alternate use...
    Soundproofing.
    I haven't tried it in a building, but I am sure someone could figure out a way to make use of it for that purpose...
    But I HAVE used it in vehicles.
    Remove the door panels on the insides of the doors. Clean inside the door, and especially clean that outer shell. Then apply the membrane like wallpaper in there. (You only need to do the outer shell.)
    Do the same on the firewall.
    If you really have noise problems, do the floor and overhead as well. (Removing the headliner, carpet, etc, to get to bare metal, then replacing those things after the membrane is applied.)
    I was absolutely amazed at what a difference it made, the first time I did it.
    I am going to have to do the tailgate of my new truck, when the weather warms back up. (Do it just like the doors.)
    Get over it....... The angry going eat you up. ~Brownbagg '06
    1. Jmadsen | Nov 30, 2006 10:33pm | #16
      I think that Luka is now in first place with his soundproofing idea!! Very Nice!!
      1. sharpblade | Nov 30, 2006 10:50pm | #18
        i used a small piece as a bandaid once after cutting myself real good.  had to wait several days before having the guts to try remove it.
    2. Jer | Nov 30, 2006 10:46pm | #17
      I think you may actually have something there. I use the auto undercoat rubber emulsion stuff for soundproofing PVC stack. Makes it even better than cast iron. The roofing membrane isn't unlike the undercoat. Good one.
      1. rez | Nov 30, 2006 11:19pm | #19
        ding ding ding
        That's a good idear. Ice/water shield around pvc drain for sound deadener.
        Dang man, hope that works.
    3. FastEddie | Dec 01, 2006 02:04am | #22
      So you stick the membrane on the outside of the truck?  Must be a Washington thing.
        Luka | Dec 01, 2006 02:13am | #23
        ROFLOLI actually had visions of that after I made that post.No... You stick the membrane to the -inside- of the outer door skin.=0)
    4. xosder11 | Dec 01, 2006 07:27am | #26
      They have a  sound dedening material like that that they charge a fortune for that used to be called something like Dynamat that they would line the inside of your car with as you described during a high end car stereo install.  Your idea is right on the money
      1. nikkiwood | Dec 01, 2006 08:34am | #27
        Luka is absolutely right.Bought a new van couple of years ago, got that expensive stuff (like Dynamat) for sound, didn't have enough, used a roll of ice/water to finish off. Worked very well, and way, way cheaper.********************************************************
        "It is what we learn after we think we know it all, that counts."
        John Wooden 1910-
    5. MikeHennessy | Dec 01, 2006 05:02pm | #30
      I've always wondered if you could use it as soundproofing on PVC stacks. I have some leftover window flashing on a current job and I think I'll try it.
      Mike HennessyPittsburgh, PA
        Luka | Dec 01, 2006 05:23pm | #31
        It works.I'm thinking it will also work for a sound deadening wall. It would certainly absorb vibrations. Just line all the stud cavities.Also thinking that now that it is going to be getting used as a sound deadener in all these ways, the price may go up...
    6. JohnSprung | Dec 02, 2006 04:45am | #33
      That gives me an idea -- Stick it to the bed of a truck before you put in a drop-in liner.  It should solve the abrasion/rust issue.
      -- J.S.
        Luka | Dec 02, 2006 05:55am | #34
        Perfect.Chuck Miller at Taunton told me this morning that a "tip" was printed one time, to use it on the bottom of a stainless steel sink, (underneath, naturally.), to deaden the sound there.
    7. wood4rd | Dec 02, 2006 06:38pm | #42
         Youre right about the door sound. I put some in the doors of my 51' Ford and its been hangin in there for 15+ years. The only drawback though is it adds more weight to the very heavy doors.    For the roof and floor I used the foil faced plastic roll, which works good for both sound and heat.
  7. jerseyjeff | Dec 01, 2006 01:58am | #20
    I used about half a roll of the stuff to cover up all the repairs I did in the cab of my POS Jeep J-10.  Quieted down the road noise a good deal too.
    I simply wasnt thinking with that truck.. The rust damage was so bad I epoxied a cafeteria tray into the driver side foot well so I would not put my foot through the floor.
    1. xosder11 | Dec 01, 2006 02:03am | #21
      Sounds like the time I went off roading in my buick century when I was in high school. the floor boards were all popped up from the boulders I ran over. I had to go out the next morning and bang the floor back down with a sledgehammer and a block of wood before my dad found out. Mysteriosly, the transmission and the oil pan had sprung leaks after that. Hmmm.
      1. jerseyjeff | Dec 01, 2006 02:37am | #24
        I wish I had it that easy!  My mechanic on at least 3 seperate occasions,  popped the hood and started pounding away with a BFH untill he got it started.  The thing vacuumed cash out of my pocket!
        JEEP  Just Empty Every Pocket!
      aimless | Dec 02, 2006 07:42am | #40
      My Dad had an old diesel Mercedes (circa 1964) that moved with him to Florida in the mid 80's.  I drove it when I visited, and you could watch the road between your feet. Creepy.  But the engine on that thing was amazing - ran like a champ long after the body was rust held together by more rust.
    3. Piffin | Dec 27, 2006 03:54am | #44
      it passes inspection like that?
      1. jerseyjeff | Dec 27, 2006 06:42am | #47
        Honestly this truck should have been condemenned and used for an anchor.  It passed inspection,  and did not spew fluids.  It had bizarre electrical issues ( my mechanic routinely beat on things under the hood with a ball been hammer)
        I covered the lunch tray with peel-n-stick then a cheep carpet so the inspectors never noticed.  They didnt get upset with the airhorns (as in from a boat)  bolted to the hood either.   When my wife got pregnant with my little guy,  I realized I needed something safe and got my toyota.  It was about the same time the truck started burning 1 quart of oil every 150 miles.  I had a 2 stroke!  I probably am going to give the toyota to my 4 year old when he starts to drive in 14 years.
        1. Piffin | Dec 27, 2006 12:47pm | #49
          Yah, one reasom Toyotas are becoming the most common name plate on the road is the voluntary attrition by other autos.
  8. IdahoDon | Dec 01, 2006 07:05am | #25
    We use it under ordinary doug fir plates instead of pt.  It's rated for underground use so we use it to waterproof foundations.  It can be used to protect wood of all kinds from contact with moist items:  under the bottom of stair stringers on concrete, attaching wood nailing blocks to concrete, etc.
    It can be rolled up, sticky side out, and placed under an exterior door threshold that is on flat concrete as a water dam of sorts (same concrete plane on both sides).  If it's rolled large enough to be slighly under compression it seals better.
    When applying exterior brackets or fixtures that are screwed into the exterior surface, a piece (with release paper intact) can be added under the bracket and carfully cut flush or slightly less than flush.  Then remove the release paper and install.  The ice and water seals the screw penetrations.  If the ice and water is slightly undersize, the slight gap created is better to hold caulking as well.
    We use strips behind wood siding corner trim and buttt joints if warranted.
    We've wrapped the inside of a large concrete planter to keep water evaporation from leaving mineral stains on the exterior.
    What can't it do!?
  9. User avater
    IMERC | Dec 01, 2006 11:49am | #28
    on top of sistered deck joist...
    WOW!!! What a Ride!
    1. Snort | Dec 01, 2006 04:49pm | #29
      We also use it to make a sealing "flange" for brick molded doors...way better than the old caulk seal. Oh God said to Abraham, "Kill me a son"
      Abe says, "Man, you must be puttin' me on"
      God say, "No." Abe say, "What?"
      God say, "You can do what you want Abe, but
      The next time you see me comin' you better run"
      Well Abe says, "Where do you want this killin' done?"
      God says, "Out on Highway 61."
    2. rez | Dec 01, 2006 05:46pm | #32
      A weapon in the war with ACQ?
  10. kate | Dec 02, 2006 06:03am | #35
    Funny you should ask...
    Any fine homebuilders who are easily offended, stop reading right now...
    At the moment, my kitchen floor is patched with peel&stick...it's acting as trim around the windows, sealing the silver bubble wrap which is my temporary wall surface (did you know you can paint it?)
    Because it will be a while before I can finish the kitchen, I also stapled white sheets on the ceiling. Keeps the dust off the table, & makes the space bearable until it gets done.
    1. user-53014 | Dec 02, 2006 06:15am | #37
      ...emergency securing of a copper downspout attached to copper gutter lining that came free from it's solder and was causing a lot of damage from the wooden gutter underneath. Wish I saw this a few years ago, would have saved me alot of headache and $$Slapped a piece on over spout then cut the circle out. By the way the Pella foil faced tape is BY FAR the most stickiest, easy-to-form, and best I have found (compared to vycor, strips of ICW and the crap shiny stuff at the dumpot. Expensive but I highly recommend. I believe only available at Pella Stores, not lowes or Pella vendors.
      1. shearwater | Dec 02, 2006 07:19am | #39
        Closing in a shattered car window.  Any window, just not the windshield.
        1. Piffin | Dec 27, 2006 04:12am | #45
          Hard to see through, ain't it?;)
        RichBeckman | Dec 27, 2006 04:57am | #46
        "By the way the Pella foil faced tape is BY FAR the most stickiest, easy-to-form, and best I have found...I believe only available at Pella Stores, not lowes or Pella vendors."The Lowes in Marion, IN carries the Pella foil faced tape.Rich BeckmanThis signature line intentionally left blank.
      aimless | Dec 02, 2006 07:45am | #41
      That needs a picture.
      1. kate | Dec 27, 2006 01:54am | #43
        Alas!  I am lacking photo - ability...
  11. booch | Dec 02, 2006 07:19am | #38
    I used it to insulate the basement sump drain tube. The outdoor flexible section was solidifying in the wisconsin winter. That wrap stuff helped dull the winters cold and allow a non freezing drainage.
    Jack of all trades and master of none - you got a problem with that?
  12. Bentstick | Dec 27, 2006 07:00am | #48
    I know a fellow with a new Corvette convertible which leaked. He stuck a piece in where the leak was to solve the problem. Kind of tacky on a $70,000 car.
    If it wasn’t for the Bank Payments,
    Interest, Taxes, Wages, and Fuel Costs,
    I wouldn’t have to charge you!!
