Unlined Masonry Chimney
VinceNW | Posted in Energy, Heating & Insulation on September 22, 2006 07:21am
Hey All,
I just got a bid for rebuilding my failing masonry chimney on my 1915 house here in Oregon. It needs to be rebuilt from the roofline up and get a new cap installed. The chimney is unlined and serves a standard fireplace which will probably get used no more than a couple times a week. The chimney folks said that they would have to rebuild the entire chimney to install a ceramic flue liner (size difference) and that by removing part of the shelf(?) above the firebox they could squeeze in a steel pipe liner….but they thought that the chimney should be safe to use unlined for the fireplace especially with about 2/3 of the chimney being new work. Any safety concerns about that? Should I try to have the liner installed now or use it for a few years unlined and then install a liner (my thought being that I may install a woodstove down the road)?
As always the feedback from this group is awesome…Thanks for the help!
  1. gb93433 | Sep 22, 2006 09:10pm | #1
    I am no expert in chimneys. Often the older chimney flues are larger than the new ones. It wasn't too long ago that you could buy concrete blocks and lay them on top of each other and put a flue liner in it and create a chimney.
    The newer flues are smaller and run hotter to create more draft and better efficiency while also keeping the flue cleaner.
    I would do a search on google.com and see what you might be able to do.
  2. VinceNW | Sep 26, 2006 01:32am | #2
    Sorry, maybe I'm not offering a clear question...
    Question:
    Is it safe to use an unlined but newly rebuilt masonry chimney with a
    standard fireplace...or is a steel liner a must?
    Thank you....
    1. dedubya | Sep 27, 2006 03:37am | #8
      Vince have you checked out a cast in place
      flu liner job, the contractor uses a inflatable
      form that they insert into the flu with clearance spacers,
      then inflate the form, then  pump refractory grout
      around the form ,after this dries they deflate and pull the form out,
      this also stregnthens the chimney,
       last time I checked the prices on this ,it was cheaper
      than a stainless flu and a whole lot less invasive.
      Edited 9/26/2006 8:42 pm ET by dedubya
        razzman | Sep 27, 2006 05:50am | #10
        I seem to recall a technique used for relining straight chimneys using a bell system that after the bell shape is dropped to the bottom of the chimney,  it is vibrated as it is pulled back up and smoothes the sides of the fresh poured liner in the process then it is done again to provide a glaze.
        'Nemo me impune lacesset'No one will provoke me with impunity
        1. seeyou | Sep 27, 2006 01:56pm | #11
          There was a system like that 20 years ago - incredibly expensive. I guess it faded away. You had to buy a franchise. I think it was the Ahrens system. Yup - here it is:http://www.ahrenschimney.com/specification.html
          "Let's go to Memphis in the meantime, baby" - John Hiatt.
          http://grantlogan.net/
          1. rez | Sep 27, 2006 02:11pm | #12
            dang yer good.
            but ya didn't invent that system
            We can imagine something that only exists in our heads, in a form that has no measureable, tangible reality, and make it actually occur in the real world.  Where there was nothing, now there is something.Forrest - makin' magic every day
          2. seeyou | Sep 27, 2006 02:32pm | #13
            No, but I considered buying a franchise at one time.
          3. rez | Sep 27, 2006 02:36pm | #14
            So it is a valid procedure that just never caught on?
            Does it have it's roots in Europe?
          4. seeyou | Sep 27, 2006 02:58pm | #15
            Yup and yup. I was looking at it in the late 70's, early 80's. At that time the franchise was $28K, IIRC. You got a couple of different size bells, the vibrator, some rods, and enough mix to do one small chimney. IIRC, they would only give me a protected franchise for Fayette County (where Lexington is), so someone else could buy one 20 miles away in a neighboring county, in theory. I wanted the entire metropolitan area which includes all counties touching Fayette and they wanted more money for each county. I think the fee was based on population.
          5. rez | Sep 27, 2006 03:02pm | #16
            And the concept never caught on. It's practically unheard of now, at least to what I've seen.
            So much for the francise operation. Sounds like they shot themselves in the foot.
          6. seeyou | Sep 27, 2006 03:06pm | #17
            Looks like they're still in business. I hadn't thought of them in years, 'til you brought it up. Out of that business for 20+ years now.
          7. rez | Sep 27, 2006 03:14pm | #18
            Seems the idea is still pretty much unknown to the man in the street, tho'. What most think of is SS liner.
            I recall in George Nash's book 'Renovating Old Houses' a technique he gave for dropping pre mortared clay tile down from the top via a rope tied to an offset stick so the weight of the flue section would wedge the stick in that flue until it got placed in the chimney and the tension could be released and the rope bought back up for another section.
          8. seeyou | Sep 27, 2006 03:25pm | #19
            I did that quite a bit. I built a tile dropper. It worked pretty well. Still had to cut into the chimney to do offsets and anything below them.
            I also had a tool to break out the old tiles.
          9. rez | Sep 27, 2006 03:34pm | #20
            So that style of operation is functional then. What is the smallest flue you ever lined that way?
            I remember the tile breaker. Looked like it would be hell if it ever got away from someone.
            help help as the blood splatters.
          10. seeyou | Sep 27, 2006 05:17pm | #22
            >>>>>>>What is the smallest flue you ever lined that way?8"x8"
          11. rez | Sep 27, 2006 06:08pm | #24
            So the tile was a 6" dia in a 2 brick width then or was the flue liner itself 8" square.?
            Edited 9/27/2006 11:11 am ET by rez
          12. seeyou | Sep 27, 2006 09:54pm | #26
            >>>>>>>>>>was the flue liner itself 8" square.?yup
          13. dedubya | Sep 27, 2006 03:45pm | #21
            I did the ,check into franchise, bit also ,but with
            the inflatable form method.18K for the grout pump-
            14' trailer-and 2 forms and their [school] ,3days
             of helping them grout chimneys, the price then was
            about 35 $ a ft. not counting what ever masonry work
            was to be done to go into the chimney to center up the
            form in the flu, they did have one of the slickest ways of
            removing the old liner out of a chimney i have ever seen
             though
          14. seeyou | Sep 27, 2006 05:18pm | #23
            >>>>>>>>they did have one of the slickest ways of removing the old liner out of a chimney i have ever seen thoughI think that's where I got the tool Rez and I are talking about.
          15. dedubya | Sep 27, 2006 07:25pm | #25
            was it a hardened metal cutter, that was attached
            to a fiberglass cleanout rod with a cable or chain?
             turned with a electric drill. When I worked in the
            cement plant we used a system to clean out cement
            silos that had gotten wet and set up ,said cement into
            volkswagon chuncks. we used two humongus atlas-copco
            compressors each capable of sustained pressure of over 200p.s.i.and
            treemendous cfpm's.each manifolded into a single 6" high pressue line that  necked
            down to a 4" travel line then down to a 1and half  rubber airline with a
            hardened steel plate about 4" squareon the end, that was inserted into the
            silo .then the compressores started that cutter whipped around
            cutting into chunks like a 50 cal. though a watermellon. man a site
            to behold!!  DW
    2. Tim | Sep 29, 2006 07:53pm | #27
      "Is it safe to use an unlined but newly rebuilt masonry chimney with a
      standard fireplace...or is a steel liner a must?"
      No and No. The chimney needs a liner. The liner doesn't have to be steel. Clay flue tiles, installed properly are safe, effective, inexpensive and probably the most common way masonry wbfp's are lined.
    rjw | Sep 26, 2006 01:41am | #3
    I don't think it is safe enough.
    The risk is carbon monoxide poisoning from combustion gases getting into the house through the unlined brick.
    Wood fires can produce huge amounts of CO.
    I wouldn't burn one fire in it.
    “Experience doesn’t bring wisdom, experience evaluation does. When you fail, stay down there for a while and figure out what went wrong. Don’t run away from your failures, evaluate them and learn from them.”
    Dr. John C. Maxwell
    McDesign | Sep 26, 2006 02:32am | #4
    I've got an old house with lots of fireplaces, and the first thing we did was have them restored.  After learning about all the options, our chimneys were opened up like zippers, and internally parged with high temp morter, new fireboxes with firebrick, and new stacks / new brick from the roofline up.  No flue liners at all.  Four chimneys; one with (2) flues, two with (3) flues, and one with (4) flues
    This was done by the most reputable chminey renovation company in Atlanta at the time (1992), and we do use a lot of them often.
  5. Piffin | Sep 26, 2006 05:49am | #5
    will they put that opinion in writing and do they haave liability inurance?
    There have een two chimney fires on my island here in ten yeaars or so thaat leaaked fire thru the mortar to wood in back walls of closets so tht the house was on fire before anyone knew here was trouble.
  6. Aaron | Sep 26, 2006 05:47pm | #6
    "about 2/3 of the chimney being new work"
    It's the 1/3 that will kill you.
    Aaron
  7. BryanSayer | Sep 26, 2006 09:04pm | #7
    I'm sure you will get lots of opinions on this. Flues didn't use to have steel liners (in fact they may not have had any liners) and many of them had no problems. But many of them did.
    You'll never go wrong (in terms of safety) adding a stainless steel liner, properly installed.
  8. seeyou | Sep 27, 2006 04:59am | #9
    You ever noticed that after the house burns down, the chimney is usually still standing?
Mortar for Old Masonry
