so I learn the hard way that GE II caulk for Tub/Kitchen is not paintable…ouch. I wonder if there is a product that I can put over this caulk to make a paintable surface. … or do I need to remove, a la scrape off, this caulk in order to paint it. Otherwise, the bathroom turned out perfect! I was hoping there was an epoxy or something to bail me out!!
FHB Podcast team chats about adding Larsen trusses to an existing stud-frame home with no additional sheathing.
schmear a film of LEXEL over it.
That sounds better than scraping the caulk off... what IS LEXEL???
a paintable adhesive/sealant caulk
Sashco.com I think. it's clear, sticks to anything, even itself.
7 bucks a tube, 50 yr stuff...IIRC
Heck, yer in Jersey...if ya can't find it, email me..I'll send ya tube.
[email protected]
will do. sounds like what I'm looking for. and yes I'm in Jersey!
aaaahhh...see? REZ...He filled out his profile!!!
Private joke..Bob
good luck, it works..really.
BTW, when ya don't use the whole tube, ya gots to use a good seal to keep it..I like alum tape ( cuz I have it handy) or saran type wrap and tape..
Just finished the first coat of finish paint on the LEXEL. Great suggestion!! Never heard of the stuff, but it acts like the "magic bullet". Spec sheet on it was quite interesting, as well. Thanks for bailing me out!!
no problem, that's what we are here for.
I found it @ Larkin Lumber, if you recognize that name. Thanks!
Edited 7/26/2004 2:44 pm ET by big bob
BUT!!!! BUT!!!! It said so on the tube..
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming.... WOW!!! What a Ride!
I thought 'Silicone II' was supposed to be paintable. That was the "II" part.
Edited 7/26/2004 3:40 pm ET by csnow
I'm not sure what the I or the II stand for with the GE silicone caulks, but paintability rating on both tubes is "no". In fact, I just got back from HD and GE now offers a special "paintable XST" tube, (I think it's called), packaged with 2 tubes of GE II. Clearly, I'm not the only one unhappy its paintability issue. I dont' think I would want to be the first one to put an "unpaintable" caulk on the market. maybe there are others, but it would surprise me.
It's been awhile but my memory tells me that the diff is in the flow, workabilioty and thermal sustainability. See if the GE II is n't rated up to 2000°F
I will check next time. thanks.
I had the opposite problem -- used paintable silicone for some bathroom fixtures. It turned yellow within a month. "Saved" it by painting the caulk with model airplane paint.
Edited 8/2/2004 7:50 pm ET by DanH
