HELP: Just finishing up a nice kitchen remodel job and plumbers putty was used and left a darkened oil type residue that can be seen around the stainless steel drop in sink. I’ve tried detergents and Acetone. Looks bad. Any help will be appreciated. There must be something out there that will remove stains from tan colored granite tops.
Making your own heated floor assembly may save money, but it can also cause problems.
Sorry. After 17 years, I ain't found anything yet that will work, short of DEEP polishing. Granite is porous, especially where the cut outs are. The oils in the plumber's putty will soak into the granite, and make surface cleaning almost impossible. If somebody here actually does have an answer, I'm all ears.
James DuHamel
*Try VIC International. A few yrs ago at the Coverings show in Orlando they had a poultice that was supposed to work wonders on stone reemoving stains. they have a web site. They are NEAR Knoxville, TN, but do not have a Knoxville phone number.Don
*Fold up some paper towels into long strips. Lay the strips on the stains, and keep them wet with acetone for a few hours. Then put some new, dry ones down, and keep them weighted down in place for a while.Just a hunch, of course. I've never tried it.
*I've done similar things, only to remove oil from concrete floors. Even better than the paper towels is to take talcum powder (Hey! Real Talcum Powder, and not cornstarch!!!!) and thoroughly wet it with something that dissolves grease. I recommend mineral spirits as it is a good grease solvent, is fairly non-toxic, and evaporates slowly enough that you are less likely to have flammibility problems.If you want, prewet the surface with the spirits, and then put the poultice on it. Let it dry. The solvent will wick out of the surface and pull the grease with it and up into the talcum.Do it again.Do it again.Do it again.(You get the idea)
*I had a sort of similar problem with a concrete tub surround. The client decided to entertain in the large jacuzzi tub before the concrete was sealed and somehow a quantity of carrot oil got spilled on the concrete. (Believe me, you do NOT want to know...)I was at a complete loss for any easy solution, was about to try muriatic acid (I believe it ws muriatic, I can make the call again if it helps you) which they use to clean gravestones, but would require a lot of safety prep, etc., or busting off and re-skimming the surround. Ohhhhhhh, not exciting propositions....The client, feeling bad, went out on their own and got some "GOOF-OFF" spray, tried it, and whaddaya know, it worked. Many repititions were required, but significant results happened each time. It is a $4 solution, which makes it worth a shot, I think.Please post the results of whatever you find that works and good luck.Don
*Uh, Don, there's no need to speak for others. I'm quite certain I would like to know. Carrot oil? Always looking for a new addition to the bag o' tricks. Ron Teti would probably be interested too - especially if the story involves shorts. Is the jacuzzi a requirement? I think you should tell before my imagination runs away from me. (Never mind - too late.) ;)
*i (Never mind - too late.) ;)And now how are you going to clean up that stain ?
*There's the line...and... yup, Luka just crossed it....
*Ya gotta get a little talcumYa gotta borrow it from MalcomName that tuneT.
*Nugent
*I had to. It was getting too messy on your side of the line.b : )
*Miraseal's Poultice Plus...says it removes deep seated stains in marble, limestone, and granite.
