So we’re supposed to be using USB 2.0 now.
As I understand, that means ALL components and the cables to hook them up.
How does one tell a USB 2.0 cable from a USB 1.0 or 1.1? All of my collection looks alike.
Or is someone pulling my cable?
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
I think the cables are the same as are the connectors. The card in the computer is 1.0 or 2.0 and the device is 1.0 or 2.0. They are backwards compatible. A 2.0 device will plug into a 1.0 card, but it will work at 1.0 speed rather than 2.0 speed.
Birth, school, work, death.....................
http://grantlogan.net/
So what you're saying is the cables themselves have no effect on transfer speeds within the whole picture. It's just the components?
Of course not. You need to go to the speciualty cable store and buy the "gold plated" cables that cost 4 times as much as the ones at Walmart. You know, the ones will all the hype about dB and rfi and fancy graphs on the package.
Speed costs money. How fast do you want to go?
That's an old Race Engine Builder quote. Can be turned into many other versions quite easily.
I've got several USB2.0 devices and I don't see any difference in the cables that came with them. The connectors are the same. That's where my geek Knowledge ends. I don't know how 1.0 is different from 2.0, but 2.0 is deffinately faster.Birth, school, work, death.....................
Though in theory the cable spec is different for USB 2 vs 1.x, in practice it doesn't make any difference unless you're dealing with fairly long cables. If the cable works, use it.
happy?
