I have a chance to pick up an old quincy Compressor. 20 – 24 scfm 100 psi, probably 40 gal. tank. Good strong 110 / 220 1ph. motor….no HP rating. He is asking $300.00. Is this a good deal? it burps strong, and a friend who knows the unit says it was working well when they took it out of service. Any thoughts out there?
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
I know nothing about the unit
But whats its cost new, and why was it put on the shelf?
No idea
Upgrade to larger unit. It ran a small cabinet shop for years.... shop outgrew it.
When I worked in industry, we had a few Quincy's around, usually small units (150 cfm)where air was needed away from the primaries (1500 or more cfm).
I remember the Quincy's as being pretty reliable and tough and a little finicky to work on.
For home use, or shop use, it might be a good deal. Those industrial air jammers are built a lot heavier than the units we pack around on job sites.
Thanks, Notch
If it's putting out 20 to 25 scfm at 100 psi, it isn't running on 120V. It's probably a 7.5 hp motor, though possibly 5 hp (real NEMA hp, not Sears Marketing hp), and is likely to be 3-phase. Do check the motor nameplate.
Be seeing you...
Old elect. motor....no rating. 220 vac. Heavy motor (Daton) tho.
Does the name plate show the current rating?
current, but no amperage. No wattage, no HP.
Isn't current listed in Amps, like weight is in pounds, etc? Give us all the info off the dataplate...there's formulae for figgerin' HP and other stuff.Do it right, or do it twice.
usually, this data plate is pre rating. not enuf listed to do the math as I recall. Cant get to it to double check. The local repair guy seems to think it is in good shape, and seems to be a better unit than what can buy new for same $$. Def. quieter.
if it's 20-22 cfm, it's probably about 7.5 hp, about the outside limit of 220 1 ph motors. But new, that compressor would probably be $1500-$2000, just guessing. Look on Grainger.com and search for compressors, you can probably find something comparable to price compare. If it runs, and doesn't have a lot of oil carryover, it seems like a good deal. If it needs rebuilding, I know a guy in MA who can do it. I was thinking of buying one of these rebuilt quincys from him a while back. Some have full pressure lubrication instead of splash lubrication, which is more heavy duty.
