Using a framing gun for wood to concrete
dotto | Posted in Tools for Home Building on December 29, 2004 03:30am
I have a few basements jobs lined up for the start of next year and was shopping PAT’s.  I have a cheap Remington that I bought a few years ago, but I’d like a gun that is better quality and semi-automatic.  A guy at the tool store suggested using the Paslode Framing gun with the concrete nails.  Are any of you using a framing gun for this application?  Paslode and Stanley list wood to concrete under the “Applications” for most of their framing guns.  Any experiences doing this?  How do the guns hold up?
Dave Otto — Otto Construction — PA
    IMERC | Dec 29, 2004 03:32am | #1
    gotta have the hardened driver for the gun and personal body armor...
    works fine...
    WOW!!!   What a Ride!
    1. FramerT | Dec 29, 2004 04:34am | #2
      We have one of those cast relic Duo-Fast guns for that...it's iffy. Sometimes it'll sink them,sometimes not. As mentioned,the driver is the key.
      I didn't do it....the buck does NOT stop here.
        scottyb | Dec 29, 2004 05:00am | #5
        Dave,buy a Hilti powder actuated tool.I've got an old DX350,.27 cal,uses 10 shot mags.I bought this tool 20yrs ago,used.Replaced the piston twice,never let the sun set on it dirty,It's my baby for wood to conc or steel!Have used Hitachi framer with hardened 8d.Works fine on cinder block and green conc.Always use glue.Still like the old standby... pre drill 1/8" hole through plate into conc,4" piece of stove wire,16d sinker.
        1. slykarma | Dec 29, 2004 06:55am | #8
          I think you mean drill 3/16" hole for this method.Lignum est bonum.
        2. blue_eyed_devil | Jan 02, 2005 05:44am | #12
          Scottyb, I can attest that they'll work fine dirty too. I bought mine in 1989 and I don't ever remember cleaning it.
          blueWarning! Be cautious when taking any framing advice from me. Although I have a lifetime of framing experience, all of it is considered bottom of the barrel by Gabe. I am not to be counted amongst the worst of the worst. If you want real framing information...don't listen to me..just ask Gabe!
          1. chills1994 | Jan 02, 2005 08:01am | #13
            Yeah, I've used the Paslode air driven framing gun to shoot 2 X's to a concrete floor.  It worked very slick.  If you ever have to pull the nails and 2X's up, like for removing braces, the concrete spalls out, but is patchable.  It was for a housing project where everything was slab on grade.
            A hammer drill with a 3/16" carbide tipped bit works well too.  A 16d nail and some tie wire or even weed wacker strings does the trick.  More time consuming but cheap on materials.
          2. Matt_S | Jan 02, 2005 08:43am | #14
            How do you use a nail and wire to anchor into concrete?
          3. UncleDunc | Jan 02, 2005 09:11am | #15
            If you drill the right size hole and use the right size nail and the right size wire, you get a compression fit.
    Bluemoose | Dec 29, 2004 04:52am | #3
    Before I moved to Florida, I'd only used a Hilti gun or hard nails (concrete nails/hand drives) for wood to concrete applications, but down here many guys use case-hard nails (not sure if that's the "technical" term) for wood to concrete.
    On block houses, we shoot case-hard nails with a Senco framing coil nailer. We'll shoot furring strips onto block, even borate treated bottom plates into the slab. I definitely recommend safety glasses, but it really isn't as bad as it sounds.
    http://www.senco.com/con_rem/ques_fast.asp#5
    Even in green concrete, I don't think the holding power of this method compares to cut nails, hardened nails, or a powder-actuated fastening method.
  3. FrankB89 | Dec 29, 2004 04:59am | #4
    If you've got more than just a few nails to drive, do youself a favor and get a good quality powder actuated nailer.
    Hilti is a good one, but the selection has grown over the years.
    I have a 27 cal. Ramset with manual advance using strip loads.  It works great, is reliable and the yellow loads are usually adequate for putting 1 1/2" furring to concrete.
    You have to take a little test to buy these things (an OSHA thing) but they're worth the effort and expense if you want to get the job done with out a bunch of monkeying around.
    1. UncleDunc | Dec 29, 2004 10:36am | #10
      Last time we talked about powder actuated fasteners here, several people suggested using Tapcons instead.
        james | Jan 02, 2005 05:38am | #11
        tapcons = slooooow but they do = Goooood holding power, depends which you need.
        james
  4. Pierre1 | Dec 29, 2004 05:44am | #6
    Keep your face well away from the gun... ;)
    1. FrankB89 | Dec 29, 2004 06:30am | #7
      Most of the powder actuated guns come with a spaul shield...pretty safe....but eye protection is always highly recommended.
  5. RalphWicklund | Dec 29, 2004 07:13am | #9
    When I fur concrete block I stand up full sheets of 3/4" or 1" foil faced board and shoot 2 1/4" case hardened nails thru the furring which holds the insulation board firmly to the walls. To make the job go faster I premark on each panel where one 1x2 will fall on 16" centers and set one nail to hold the board in place. I use a 1x4 at the bottom and at the top of the wall and around each opening. To place the precut furring I use a scrap of 1x4 as a spacer at the bottom.
    If an insulation panel will cover most of an opening, I omit that board and place the next, etc. When all boards are tacked in place I cut out windows and doors and use the scrap to fill in the sections under and over openings I skipped. Less waste that way.
    I then go back around the room(s), add the rest of the furring, plumb each and shoot the rest of the nails, adding the top and bottom and the opening surrounds of 1x4.
    Can't say how this would work for the rest of the country but it is great for my area of NE Florida. Sorry, no basements here, either.
    I use a PC RH350 and only once in a while have to finish off a shot by hand. If the gun won't put the nail home then it usually ends up bent over 'cause it won't go in any deeper.
    In addition, furring OVER the insulation board allows the use of untreated furring which is good for me because I have a source for free 1x2 pine furring and don't have to worry about the corrosive properties of ACQ.
      Bluemoose | Jan 02, 2005 07:15pm | #16
      Hey Ralph,You are in/around Jacksonville, no? I think I remember seeing pictures of your residing/rebuilding job in Jax. How's that job going?Your free source for 1x2s, do you have to get those borate treated, or does it not matter because they're inside and not in direct contact with the concrete block? Have you ever done furring on the outside of block for Hardi, etc? What do you use? We use borate treated material, but I've heard that it should also be wrapped. I'm having to learn a good bit of new methods in dealing with this block.
  6. dinothecarpenter | Jan 02, 2005 09:35pm | #17
    A super caulking gun and liquid nails. Then you can use any other gun to just hold the plates in place until the glue is set.
    If you use the liquid nails as the  primary holding method, you only need to drive the nail into the floor 1/4". You don't even have to use a gun.
    EZ Dino
      IMERC | Jan 02, 2005 10:00pm | #19
      liquid nails won't make the grade... It's some seriously worthless stuff....
      PL Premium....
      WOW!!!   What a Ride!
      1. dinothecarpenter | Jan 02, 2005 10:08pm | #20
        PL Premium....
        I knew that. I just wan't to see if you knew it. :)
        You right. PL Premium is it. IMERC,   Do we get any money back?
        EZ Dino
          IMERC | Jan 02, 2005 10:12pm | #21
          from PL or Liquid nails...
          or a DIY'er...
          WOW!!!   What a Ride!
          1. dinothecarpenter | Jan 02, 2005 10:22pm | #22
            I think next time we make a deal before we give the EZ  right answer.
            We can send a contract to the customer with a non disclosure agreement.
            And we only ask for 20% of the savings. What you think?
            Is EZier to pimp Ideas then tools.
            partners?
            EZ Dino
            IMERC | Jan 02, 2005 10:23pm | #23
            you take the 20 amd I'll go fer the 30%...
            total savings to the customer... 50%....
            that'll work fer me...
            WOW!!!   What a Ride!
          3. dinothecarpenter | Jan 02, 2005 10:57pm | #24
            EZ Money.
            That remind me of one big Job for an army base. NJ. We suppose to nail Z-strips -insulate and drywall/painting  the hallways and stairways of 5-6 buildings while people work there.(offices) with (centerblock walls)
            So,I bought the cheapest gun and only the min.quantity of nails. And  10 boxes of spray cans foam insulation. With the first BUNG the spec's was thrown out the window by a general. He was so upset,he thought we're under attack.
            But when he realize that was a nail gun he calm down and ask me if we can have the job done without the gun.
            - But the specs general.....
            --What specs he said and throw them out from the window. do you see any specs?  Sorry guys that you may lose a day but we can't have this here.
            -Don't worry Sir General. We don't have to lose another second . And I open the first box with the foam spray cans.
            --So, Is that why you start next to my office?
            -Yes Sir General!!! we don't want you to feel bad about us losing a day.
            EZ Money IMERC.
            EZ Dino
            IMERC | Jan 03, 2005 04:08am | #27
            sounds like you worked over at MacDill...
            WOW!!!   What a Ride!
          5. dinothecarpenter | Jan 03, 2005 04:22am | #28
            So many places... This one was in south jersey and the name don't pop right now. I have to ask one of my guys. I'm baaaad with names.
            IMERC | Jan 03, 2005 04:40am | #29
            Tampa Fl....
            WOW!!!   What a Ride!
          7. dinothecarpenter | Jan 03, 2005 06:02am | #30
            Ya. Tampa Fl...NJ.
          8. User avater
            IMERC | Jan 03, 2005 06:07am | #31
            'bout the same...
            WOW!!!   What a Ride!
    2. blue_eyed_devil | Jan 02, 2005 11:50pm | #25
      I agree YC. I've glued a lot of plates to the floor as well as to the steel beams. You just have to figure out a way to keep the stuff fixed till the glue sets.
  7. nicktonails | Jan 02, 2005 09:54pm | #18
    I use a hilti gun thats semi automatic and you can move along pretty fast with it . you can get one on ebay used for undre 2 hundred and they last forever,  most come with a replacement barrel.
                               kennedy nichols
    1. dotto | Jan 03, 2005 02:05am | #26
      I will check out Ebay.
      I like to use the PL Premium as well.
      Thanks all for the input.  Dave Otto -- Otto Construction -- PA
