Hey all,
I know lot’s of people on this board use IrfanView to resize digi pics, and I have it installed on my computer. What is the series of commands and mouse clicks to resize a .jpg to make it smaller. I poked around the program with no luck.
Jon
I just started using it.
Image > Resize/Resample
Go crazy.
Thanks Bob.
Just tried it. boy that was easy.
Jon
BTW, also have Photoshop Pro, that one is a monster to use.
I got Irfanview because I just got a new PC with WinXP Home Edition, and my Adobe PhotoDeluxe 3.1 won't run on XP. I had used the Adobe principally to resize JPEGs from my digital cam.
Irfanview is far easier.
Danger Will Robinson! After you do the resize routine, do a save-as with a slightly diff file name so you always have the original higher quality file to go back to.Whenever you are asked if you can do a job, tell'em "Certainly, I can!" Then get busy and find out how to do it. T. Roosevelt
