UV protective Deck Finish recomendation?
MrSQL | Posted in General Discussion on May 15, 2009 04:41am
Hello,
I’ve decked my back (covered) porch with 5/4 white oak (wo) [screwed and plugged].  Also wo posts, rails, steps.
I like a natural finish, but would like something that is also uv protective so it will retain it’s natural color (areas uncovered such as the steps are already very dark grey).  I plan on pressure washing first then applying the finish.  I’ve used Thompsons Water seal, but I don’t think it is UV protective.  One other thing:  on past decks, I’ve pressure washed avery other year and re-sealed, so I am expecting that there will be maintenance for whatever finish I use.
Thanks,
Roger
BTW:  I’m custom making/instaling walnut trim [sort of Federal style] for windows and doors [interior], so I hope to be posting pictures soon.
    Sphere | May 15, 2009 04:43pm | #1
    Pen-o-fin. case closed. Every year.
    "If Brains was lard, you couldn't grease much of a pan"
    Jed Clampitt
    Haystax | May 15, 2009 05:16pm | #2
    What Sphere said...
    I used Superdeck for my cedar siding but am now sold on Penofin products.
    FWIW, Thompsons is junk
  3. GRCourter | May 15, 2009 06:17pm | #3
    Another product to look at is Sikkens Deck Oil.
  4. webted | May 15, 2009 09:26pm | #4
    Third vote for Penofin - although I've only used it on cedar, not white oak.
    HD carried it a few years ago, and I got 3 small drums (5 gal) for $20 each when they closed it out...
    One caution is that you might need to rough filter it before running it through a deck sprayer (even one of those cheap hand pressure type $20 - $30 spray cans) - I had two cans of Pen. with enough solids in it to give my sprayer a stroke. We were spraying with a brush down because we were doing a deck and a fence. The stuff is an irritant, so watch out and wear a filter or stay upwind if you do decide to spray.
    -t
    MrSQL | May 26, 2009 06:45pm | #5
    thanks all.  I'll check into Penofin and compare also sikkens deck oil.
    Regards
