Vapor Barrier
nkhandyman | Posted in Energy, Heating & Insulation on June 10, 2014 05:01am
Would someone direct me to the ICC section that discusses when an air (vapor) barrier is required.
Helping to build a home for Habitat for Humanity.  OC foam in the walls; blown in celluose in the attic.  Local BI told us that a plastic air barrier is needed over the foamed walls prior to drywall; and on the ceiling prior to drywall.
Have built last 4 houses the same way and no plastic was needed.  Thank you.
Fast, Accurate Wall Framing
