I’ve been told by one contractor that he never uses plastic sheeting on unfaced insulation batts but uses PVA (poly-vinyl acetate) applied with a roller over the sheetrock to create a vapor barrier. Is this sufficient? he said the code here (Wa. state) allows it.
Traditional lime wash still has tons of useful applications.
I've been told by one contractor that he never uses plastic sheeting on unfaced insulation batts but uses PVA (poly-vinyl acetate) applied with a roller over the sheetrock to create a vapor barrier. Is this sufficient? he said the code here (Wa. state) allows it.
