Vapor Barrier Detailing for Concrete Slab
scarbelly | Posted in Construction Techniques on November 4, 2010 05:27am
So I’m preparing to pour a concrete slab on grade in part of a daylight basement. I’ve finished the excavating and placed and compacted the base. I’m further along than the picture shows. I’m wondering how people typically finish the vapor barrier along the wall or top of footing prior to pouring concrete. I’ve seen details where people leave excess vapor barrier up the wall and then trim it after the concrete is poured, but a friend recommends taping it just below the top of the finished concrete slab. I can see the advantage of this since my snapped lines for the top of slab elevations won’t be covered up by the vapor barrier. I’m wondering if you guys have any advice? What kind of tape to use? I’m weary of investing in Stegotape since I’d really only need about 80 linear feet. Maybe just duck tape? I have swellstop all around, so it only has to survive the pour, right? Thanks in advance!
A little background. The slab is going in kind of a strange space directly beneath my single car garage that daylights to the backyard. The garage is on a suspended slab above it. For whatever reason, the original builder and subsequent owner never poured a slab in the space despite having it mostly excavated. It has concrete walls all around except for the daylighting wall which was wood framing. Needless to say, the framing of the daylighting wall was pretty distressed from all the moisture in there for 40 years, so I reframed it with a garage door rather than replacing everything. The room is 10’x28′.
  1. DanH | Nov 04, 2010 06:52pm | #1
    Keep in mind that whatever you do the vapor barrier won't be "perfect".  Someone will punch holes it while pouring concrete, or the tape will be torn loose along an edge.  And even if the plastic is perfectly applied, some mosture will seep through, and more moisture will do an "end run" around it.
    What you're after is "pretty good" -- no need to lose sleep over it.
    1. davidmeiland | Nov 04, 2010 07:31pm | #2
      A vapor barrier that is 99% intact
      is 99% effective.
      I would tape the VB to the wall below the snap line with whatever tape will stick. Another option might be something out of a caulk tube, like acoustical sealant. I've heard of folks using the Tremco brand to stick VB to itself and to concrete.
      1. DanH | Nov 04, 2010 07:50pm | #3
        He's got (old) masonry walls.  Moisture will come through those regardless.
        1. davidmeiland | Nov 06, 2010 08:21pm | #5
          His post
          says he has concrete walls, I see nothing about masonry. My suggestion is that the VB protect the bottom and the edges of the slab, that's really about all you can do.
          1. DanH | Nov 06, 2010 08:45pm | #6
            Concrete and masonry are essentially the same thing.  (Yes, technically poured concrete isn't "masonry", but whether poured or block the walls will let moisture through.)  And my suggestion was the same as your last one -- simply do the best you can and not worry about it.  It doesn't have to be perfect.
  2. toolpouchguy | Nov 06, 2010 06:54pm | #4
    I have not found a tape to stick to concrete ,I have even tried ice and water in the summertime
    1. [email protected] | Nov 08, 2010 02:40pm | #7
      Stucco tape
      There is a masking tape made expressly for stucco, that sticks well to concrete.
  3. [email protected] | Nov 08, 2010 02:43pm | #8
    Nailing it up with the expansion joint
    I'd just put it against the wall, and put the expansion felt over that, and then nail the felt to the wall.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
