Vapor Barrier Penetration Cone
| Posted in General Discussion on December 4, 2000 08:52am
I was wondering if any of you folks might might be able to help me locate the following item I have seen used here in the sub-arctic. It’s a tapered cone with a flange around the perimeter of the large end.A sealant is applied to the flange and the cone is inserted through the vapor barrier.A single or group of “romex” (non-metalic sheathed cable)is inserted through the cone and expanding insulating foam is used to seal afterwards.Any info would be appreciated!Thanks-Cliff
  1. Gene_Leger_ | Dec 04, 2000 08:52pm | #1
    Cliff. Try the following URL: http://www.NoRTH-RTHN.org. This is a canadian web page. GeneL.
  2. Cliff_McHenry | Dec 04, 2000 08:52pm | #2
    I was wondering if any of you folks might might be able to help me locate the following item I have seen used here in the sub-arctic. It's a tapered cone with a flange around the perimeter of the large end.A sealant is applied to the flange and the cone is inserted through the vapor barrier.A single or group of "romex" (non-metalic sheathed cable)is inserted through the cone and expanding insulating foam is used to seal afterwards.Any info would be appreciated!Thanks-Cliff
Picture-Perfect Pergola
