Vapour barrier x 2?
Vwright | Posted in Construction Techniques on April 20, 2008 03:52am
 Hi guys, I’m still working on my floor. It’s a small cottage with no foundation, just pier blocks. I’m going to put the vapour barrier down and started thinking about how to  seal the weather out. I’ve got the sub floor out and I’m looking at dirt and rock. I’m thinking of tacking cement board from the bottom of the outside joist down to the vapour barrier and then sealing it with caulking/expanding foam. First, does this sound logical? If it does, then do I have to put a vapour barrier below my hardwood? Thanks for all your help.
Vern.
Edited 4/19/2008 11:41 pm ET by Vwright
Edited 4/20/2008 12:08 am ET by Vwright
  1. Piffin | Apr 20, 2008 03:51pm | #1
    What is your climate and how far from dirt to framing?
    1. Vwright | Apr 20, 2008 05:57pm | #2
      I'm on the west coast of B.C. It's very mild, wet, winter rain comes in sideways. The ground underneath is conglomerate bedrock and loose rock. It varies from 1/4" to 2' away from the joists. I noticed when pulling up the sub floor that the rot and rusty nails seemed to get worse in the 18" closest to the wall.
      1. Piffin | Apr 20, 2008 10:16pm | #3
        Have you thought about spraying foam insulation up under the subfloor?
        1. Vwright | Apr 20, 2008 11:33pm | #4
          There just isn't the room for spraying. I just spent a while chipping rock away where the joists were touching the bedrock so that I will have room to stretch the vapour barrier.
          1. Vwright | Apr 21, 2008 05:28am | #5
             I was hoping to avoid the plastic on the ground but it seems there is no other way. There are many little posts/supports, lots of rock and some drain pipe. I'm also dealing with 680 square feet made up of four separate constructions. I'll have 3/4 of it done by next weekend. I'm going to lay as much plastic as I can manage/reach then join to it when I rip up the next piece of floor. I'm also looking at renting a jack hammer to break up some of the rock next to house to get better slope away from the house.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
