Vaulted Ceiling sheathing
Tachi | Posted in General Discussion on July 23, 2006 09:50am
I am trying to identify a product and am having difficulty picking the right name, I guess.  In the old days, ceilings, and roof decking were often created with tongue-and-groove boards.  Nowadays, you can get that ‘look’ with a 4×8 sheet.  What the hell is it called?  I thought it was bead board, but got all kinds of strange results on the web when I went looking.
Thank you.
tachi
Family in Tucson, business in the Far East, and heart in the Colorado mountains!
  1. piko | Jul 23, 2006 10:51am | #1
    I know a product called Ranchwall (in Canada)... heavily-grained plywood with grooves at 8" o/c. Available in 3/8" and 5/8" thicknesses.
    All the best...
    To those who know - this may be obvious. To those who don't - I hope I've helped.
      Sphere | Jul 23, 2006 08:30pm | #5
      The stuff you refer to is called T1-11  here. T stands for Texture.
      " I am not an Activist, I am, a Catalyst. I lay around and do nothing, until another ingredient is added"
      1. piko | Jul 25, 2006 08:27am | #10
        Thanks. I've seen it as that here, too, but it slipped what is laughingly called my mind.All the best...
  2. calvin | Jul 23, 2006 02:29pm | #2
    We called it Beaded Ceiling:
      Paneling, Beaded Ceiling
    View Image America's first lumber was sturdy Southern Pine. Today, it's still making history...even indoors. Discover the richness, warmth, and durability of Southern Pine flooring, wainscoting, paneling, and beaded ceilings. Southern Pine lends traditional elegance to any decor. It's readily available, economical, and offers superior workability.
    The Western Wood Products Association offers a tipsheet on selection and installation of paneling. (To view the PDF, you will need Adobe Acrobat Reader, available as a free download from Adobe).
    To find a dealer, distributor or producer, go to the Product Locator.
    Ceiling and Partition
    http://www.southernpine.com/paneling.shtml
    Google "Beaded Ceiling", several pertinent links.
    Quittin' Time
    BillHartmann | Jul 23, 2006 07:21pm | #3
    Is this what you are looking for.
    Ply-bead is a trademarked name from a from GP, but most lumber yards would know what you ment even if they had a different brand.
    http://www.gp.com/build/product.aspx?pname=Ply-Bead%C2%AE&pid=2012&hierarchy=brand
    Huck | Jul 23, 2006 07:28pm | #4
    Roof decking is covered by the roofing material, so it wouldn't make sense to duplicate a tongue-and-groove look.  And unless the ceiling is less than 8' across, even the ply-bead panels are going to have a pretty obvious 4' long butt joint every 8'.  Perhaps this is going between ceiling beams?  It seems this stuff's main application is wainscoting on interior walls, or sheathing on "protected" exterior walls.  Just trying to visualize what you're doing on this project.  Let us know how it comes out!
    "he...never charged nothing for his preaching, and it was worth it, too" - Mark Twain
    1. Tachi | Jul 24, 2006 02:24am | #6
      Thanks to everyone for the response.  It did help, and it did provide the answers I was looking for.  THe intent here is to have an exposed, vaulted ceiling, but with that wood look.  One solution is to actually install T&G bead board.  It would require more labor, and it is more expensive than the 4 x 8 sheet solution, but it is also real pine and can be stained instead of just painted.  Then the SIP roofing panels are installed on top of the bead,  a moisture barrier on top of that, then and finally the roofing material.  So, it is solid from bead board to roof, no air spaces, and about R40 insulation value.
      Thanks!tachi
        trout | Jul 24, 2006 04:12am | #7
        Faking T&G never looks right on ceilings.  My vote goes for the real deal.
      2. calvin | Jul 24, 2006 05:17am | #8
        check-out 1x8 T&G barnsiding.  V-groove every 3'', notty, stains out pretty nice.  Quick coverage. A great place for Information, Comraderie, and a sucker punch.
        Quittin' Time
        1. Tachi | Jul 24, 2006 10:05am | #9
          Thanks, Calvin.  I will check it out.  Sounds like the kind of thing I am looking for.
          Tachitachi
