vaulted ceiling with recessed lighting
jergrimes | Posted in General Discussion on August 19, 2005 05:00am
719.1
Hello everyone.  This is my first post and appreciate any advise you can offer to me.   Except for the kitchen, the main floor was originally constructed with a vaulted ceiling.  The studs are 2X12 with 12 inches of rolled insulation (R-38).  There is no ventilation between the drywall and roof – only insulation.
With the help of a friend I have removed the dropped ceiling so that the kitchen is also vaulted.  The  kitchen/dining area is 10’X25′ with the peak being 10′ across.  The ceiling is 12′ high at the peak and 8′ on each end.
At my wife’s request, I had planned to install recessed lights in the sloped ceiling – 8 of them placed strategically around the kitchen with a 9th one directly over the sink.  There would a hanging light over the dining room table at the “other end” of the room. Seemed like a good idea to install recessed lights.  However, now I am told that recessed lighting is not recommended in sloped ceilings because of the lack of ventilation and consequently moisture problems (see Handyman magazine’s most current publication).
It has been suggested by my friend that, if there is room between the electrical can and the roof, I could install foam insulation directly above the can – with the regular rolled insulation in the remainder of the ceiling.  Perhaps this would significantly reduce the condensation since there would be insulation between the heat source (the can) and the roof.  What do you think?  Would that work?  Would it be dangerous to do?  Any other ideas or concerns?
I would use 6″ IC fixtures.
Thanks for your input.
  1. custombuilt | Aug 29, 2005 12:46am | #1
    seems like there's an echo in here?  I remember responding to this question before.
    I don't see a problem with that, i've seen it done before......but i'm not an electrician.  Also the cans have different insolation setback requirements per manufacture specs.  I put some in my basement and they were 4 inches of space between them and the insolation---if you have enough space, i'd just calk the entry hole good to seal it up so you wouldn't have any moisture entering in the air from below-----
    but then, what do i know?  just my opinion
    When in doubt, get a bigger hammer!
  2. Barry | Aug 30, 2005 07:41pm | #2
    We have a vaulted ceiling with a couple of recessed lights.    One issue I have run into is that in the winter, the snow on the roof over these lights melts much quicker than elsewheres on the roof and caused an ice dam issue.    I now have heat cables along the edge of the roof that got rid of the ice damm issue.
    The lights do look great.
