looked at a job that had a very poor job of VCT tile install. most of the cuts around cabinet legs etc. were very bad. what is the best way to make interior cuts in these tiles. 12×12 tiles.
thanks
orbs
thanks
orbs
My understanding is that you need to heat up the tile with a heat gun or blow torch from the back side (to avoid staining) to soften the material, then it cuts quite easily with a sharp utility knife.
I know installers use an overlay method the measure the cut dimensions quickly, but if I were doing it myself, and the cuts where complex, I would take cardboard and cut it with scissors as a template, turn the tile over and draw the template there, heat it up with a torch and cut it and voila, a perfect fit.
I think. And yeah, I would probably be there long after the pro's would have left.
Draw your cuts out with a pencil first you can be extremely detailed. Soften with a heat gun be really careful they scorch easily. Cut on a peice of wood backer with a sharp utility knife. Good Luck
Jason
thanks all. are we talking propane torch..will a hot air gun work
thanks
orbs
Both work, I think the torch scorches easier. So I prefer a heat gun for stripping paint. You could try a hair dryer in a pinch but it would probably be a little slow.
Jason
Hot air gun. Heat both sides along the cut line. First one side then the other. It really doesnt have to be heated that much to make a world of difference in cuts. Also,if you need to drill through vct as in stair nosing, heat first so it wont break.
bump thanks guys
