Veneer plywood stair treads / open riser
MatD | Posted in General Discussion on March 19, 2008 10:07am
I need 1.5″ actual thickness material for a set of open riser stairs in my new home construction.  The stringers are steel and meant for a 2×12 as the tread.  Treads are 3 feet wide.
I am not really a fan of the 2×12 pine look, and just got a price for some solid cherry.  WOW.
Would there be any problems using a veneer grade plywood (like birch) and face gluing 2 pieces together for the tread?  What sort of strength vs solid lumber could I expect?
  1. hartlandboy | Mar 19, 2008 11:26pm | #1
    I believe your hardwood is the stronger.  Having said that, the plywood would certainly be strong enough for treads if there is centre stringer & I assume there is.  Having said thatttt I wouldn't use the plywood.  The veneer is very thin and would probably show signs of wear long before it should & it just wouldn't look good.
    I would spend the $ on the cherry.  Last a lifetime and looks better with age.  Plywood is plywood is ........
    Gary
    Sphere | Mar 20, 2008 12:01am | #2
    4.5 BF per tread, and Cherry can be had for 5.00 per BF ( around here) =22.50 per tread. Unless ya have a LOT of treads, a typ. stair is still under 400.00. Say 16 treads or less.
    Ply wood at 60.00$ / 32 sqft =1.87 sqft..x 6 sqft per tread=11.25 x 16 ( the number I used above for treads) =180.00.
    Labor to rip ply and laminate=1/2 day?  Edge applied to laminates? ..Poor wear resistance?
    I'd be all over the solid wood...Oak can be even cheaper at 3.50-4.00 a BF ( again, here).
    EDIT: waste factor of plywood= only 4 treads per sheet, takes 4 sheets , now the cost is 240.00 and you have 4 2'x4' waste hunks..
    Edited 3/19/2008 5:04 pm ET by Sphere
  3. reinvent | Mar 20, 2008 02:22am | #3
    Hardwood comes as 6/4 or 8/4 and since you want 1.5" treads the stock has to be 2" to start with a 1/2" of waste turning into dust. If you could get by with 1.25" treads you would save a chunk of money.
    Ash is the cheapest hardwood that I know of ( about half the cost of cherry) but call a local hardwood supplier and ask them for suggestions.
Two Ways to Test Windows
  • The New Old Colonial
