Vertical Mounted 3 1/4″ x 10″ Exterior Vent?
I’m venting to the outside the cold air that my heat pump water heater generates.
Because of constraints, I can only use 3 1/4″ x 10″ ducting, and the best location to go through the exterior wall would require me to mount the 3 1/4″ x 10″ vent vertically rather than horizontally.
Are there any 3 1/4″ x 10″ vents that are designed to be installed vertically? So far, all I have seen are those are horizontal.
Thanks.
Tom
Sheet Metal Shop
It won't cost much to have one made at a sheet metal shop. Either a lovered vent or an eyebrow type. The eyebrow will be better if you want a damper on it. Loover will be better if you want it low profile.
