Vertical Siding Installation
WW_wannabe | Posted in Construction Techniques on April 3, 2003 02:54am
Now that I have decided to go with 1×8 Cypress shiplap (thanks to many who helped) I have couple more detailed question. The Cypress will be stained all 4 sides and has a 1/2″ shiplap. I can increase the shiplap to 5/8″ or 3/4″ if the added protection (water intrusion) justifies the added cost. What do you think. BTW, I checked and Cypress will be KD to under 20% MC.
It appears that I should plan for some water getting behind the siding. Since I am doing the work myself I am not sure if I can build a proper rain screen wall as was recommended in earlier discussions. But to add protection against effects of moisture siding will be applied on horizontal nailing strips to provide proper ventillation. I will also apply siding so that the lap is opposite to the prevailing wind direction. This will minimize driven rain most of the times.
To add protection for wall sheathing (and some additional insulation value to the 2×4 wall) I would like to install 1/4 fan-fold type insulation. Now the main question. I am wondering if I can fully cover the wall with insulation and apply nailing strips on top of the insulation. The potential problem being the deterioration on insulation (do not think they do but have no experience) causing the nailing strips to become loose.
What is recommended, size wise, for nailing strips. 1/4″ gap should be good for ventillation but that thick a strip does not seem strong enough. I would like it to be wide enough so that in cases where 2 siding pieces have to butt (45 deg. bevelled overlapping joint) I have enough width to prevent splitting of siding due to nailing close to the ends. This is where I think that applying 1/2″ thick the strips directly on to the wall will allow me to go with stronger wood and the gap will be reduced to 1/4″ by the insulation.
Thanks,
Imran
  1. roofdoc | Apr 03, 2003 03:49pm | #1
    recantly went to supliers open house and seen a product by Benjamin Obdyke home slicker that might be exactly what you are loking for try  http://www.benjaminobdyke.com
    1. WW_wannabe | Apr 04, 2003 05:22am | #2
      Thanks for the tip, it is the ideal product for my situation or any vertical wood siding. Called a local dealer for home slicker. It is $77 + freight for a roll covering 150 sq.ft. Not that it matters, too expensive for my project, I assume there are some additional parts as well. For example above door and window openings the water probably needs to be sent sideways.
      Imran
