Vertical Siding Overlap Detail
dsjack | Posted in General Discussion on April 27, 2016 03:18am
I’ve noticed that the gable ends of barns tend to an upper course of vertical siding overlap a lower course. See attached image for example. I’m guessing this is because a single board cannot span the entire height of the gable end, and the overlap is a simple way to shed water across the horizontal joint. What I can’t figure out is how you get the upper boards to bend out and overlap the lower course. If you know, please do share!
  1. oops | Apr 27, 2016 04:46pm | #1
    Normally, they would simply furr out the upper siding equal to the thickness of the siding below.
    1. dsjack | Apr 27, 2016 05:39pm | #3
      Got it. Seemed like a lot of work to achieve the overlap detail but I guess the detail is worth the effort.
      1. finefinish | Apr 27, 2016 09:48pm | #5
        Hey Ds,  That's not a lot of extra work at all.  For the barn shown it would take no more than a half an hour for 2 guys to pad out that upper gable end.  All it would need is 4 or 5 coursed of horizontal nailers to nail the siding to.
    Mike_Mahan | Apr 27, 2016 05:08pm | #2
    No gable end studs
    My guess is that the barn was built with the gable ends open and that the boards go from the end rafter to the wall below.
  3. oldhand | Apr 27, 2016 09:29pm | #4
    and..
    And it saves the effort of having to cut a bevel on the boards ends or other weather resisting techniques. Also one more opportunity for encouraging air flow into the loft if the overlap is spaced to include a vent space.
Outdoor Lighting
