Very Small Bath Remodel
popeye87 | Posted in General Discussion on September 24, 2005 01:06am
I need to move the toilet, left of it’s original position, somewhere in the range of 3″ to 6″.
 What would be the best way to do this? I’ve considered offsetting with a pair of 3″
street 45’s which would give about a 3″offset, would that restrict the flow too much?
  1. Shacko | Sep 24, 2005 06:06pm | #1
    That should be fine; the less angle the better the flow. Luck.
    1. popeye87 | Sep 24, 2005 06:32pm | #2
      would there be an advantage to go to the 4",considering the bends?
      1. Shacko | Sep 25, 2005 05:48pm | #9
        Where I live [N.E.] you can pick up two toilets on a 3 in. branch on the horizonal, you don't have to go to 4 in., no problem.  Lots of luck.
  2. ponytl | Sep 25, 2005 12:44am | #3
    if you can live with 2" you can use an offset hub/flange... very easy...
    p
    1. popeye87 | Sep 25, 2005 01:09am | #4
      How much offset (center to center) would a "offset /hub flange give me?
      Isn't it bit unorthodox to use 2"?
      1. FastEddie | Sep 25, 2005 04:22am | #5
        Nice try.   The offset flange would give you a 2" move.
      2. Shacko | Sep 25, 2005 06:01pm | #11
        Yes!
      3. ponytl | Sep 25, 2005 06:40pm | #12
        it's not 2" pipe... it's a watercloset (toilet) flange that has an offset built into the hub/flange...  they are made for 3 or 4" pipe but with a builtin offset 2" max is what i've seen... pretty common where plumbing or walls were laidout wrong.. but in anycase allows you ro move the fixture upto 2" in any dirrection.... in refits helps to mis joists all the time...
        p
        1. popeye87 | Sep 25, 2005 11:44pm | #13
          Really need more in the vicinity of 3-4". Will look into that "watercloset (toilet) flange that has an offset built into the hub/flange" just for future reference.
    2. Shacko | Sep 25, 2005 06:00pm | #10
      Maybe I read your post wrong, but you can't run 2in. to a toilet.!
  3. piko | Sep 25, 2005 07:29am | #6
    Just thought I'd ask - did you check the joists for run or spacing? Can you, in fact, move where you want?
    ciao for niao
    To those who know - this may be obvious. To those who don't - I hope I've helped.
  4. BillBrennen | Sep 25, 2005 09:55am | #7
    popeye87,
    What Shacko said in post 2. If you don't have to cross a joist, a pair of 22's (aka 1/16 bends) will obstruct less than the 45's will. It is not legal to run 4" fittings into 3" downstream. Sole exception is 4x3 closet bend.
    Bill
    1. popeye87 | Sep 25, 2005 01:45pm | #8
      I've got 12" from center of the 4" cast stack hub to the joist edge.
Choosing a Paintbrush
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
