Vinyl Decking Question
Blackcomb | Posted in General Discussion on October 1, 2009 05:11am
Hi Everybody,
We are dealing with a deck where the vinyl deck membrane has been returned up small 2ft walls that are all rotten. We are hoping to pull the vinyl decking back a small amount repair the rotten framing and re apply the membrane.
Has anyone done this or have suggestions the deck material is only about 6 years old.
Any advice would be great
    Matt | Oct 02, 2009 01:56pm | #1
    Consider this a bump...
    For me, your description is a little hard to follow.  Are you saying that you have both vinyl decking and a vinyl membrane or what?  Anyway, it something rotted prematurely, it sounds like you are either trapping water/moisture or not preventing it's intrusion.
    Edited 10/2/2009 7:15 am ET by Matt
  2. jojufernando | Apr 20, 2011 01:12am | #2
    Vinyl decking is one of the easiest and most reliable products with which to build a rooftop deck or any other deck for that matter.
    Essentially the material is a thick durable plastic material with a decorative or textured top surface that comes in rolls 5' or 6' wide.so you can use
    <a href="http://http://profektdecks.com/vinyl-decking-vs-composite-decking-vs-profekt-decking">Vinyl Decking </a>
    . There is another option i.e profektdecks .Profekt decking, on the other hand, helps you get rid of all the disadvantages present in  vinyl decking.
Grout-Free Shower Panels
  • A Postwar Comeback
  • Natural Simplicity
