I have avoided using vinyl as long as I could,… but times change. The last house had a 12/12 gable end over the garage, and I put those vinyl fishscale things on it, and hey,… it didn’t look too bad.
That trick is getting old though! Lots of folks are doing it now…and now I have two more to build, and must use a lot more vinyl this time. So I am trolling for ideas, links to ideas, and any advice anyone has about vinyl- good brands, bad brands, what to look out for etc. I know very little. I won’t be installing it myself. All comments appreciated.
The last siding I put on was Oracle, made by Crane siding( http://www.cranesiding.com ). It wasn't too bad at all. Nice vinyl thickness and everypart of it is solid core( has insulation on the back of it, corners and all). Check into different types of trim other than just J channel. Alcoa has some nice stuff like crown mold, dentil mold, fluted corners and wider lineals for window and door casings. Wolverine has siding you can hang with a roofing nail gun, hangs alot faster.
Greg
Werner Building & Remodeling
Huntingdon PA
Certeed carries some pretty good stuff.
Here's vynal on vynal in 5 shades of white and 2 shades of almond...
Edited 2/19/2004 11:02:14 PM ET by IMERC
your place?? A bad day at home is still better than a good day at work
No sir. That house belongs to a city sliker. Just did the work
The reason I asked is, what's with the false miter angle on the lineals? I cut mine at 47* and seem to hold good and tight. Is there an advantage to cutting it as you did? Being a perfectionist, I'm always looking for those perfect details<G> A bad day at home is still better than a good day at work
3-1/2" material to 5-1/2" lapped interlocked joint...
ahh...3 1/2 to 5 1/2...I had to go back and see, I missed that. Looks good. Just the miter caught my eye. A bad day at home is still better than a good day at work
This is my place
nice and private...I like it A bad day at home is still better than a good day at work
Private's not the word. Miles as the crow flies to the nearest neighbor...
Certainteed...good quality and a company that stands behind its product 100%. I had a concern with my siding, it was all replaced and my labor for R&R also reimbursed...$90 per sq.
