Vinyl Siding with Bostitch Nailer
erk | Posted in Tools for Home Building on September 1, 2005 10:46am
Hello, <!—-><!—-> <!—->
I have a RN45? Bostitch Coil Roofing Nailer that I would like to use for attaching vinyl siding.  It looks like Bostitch has an attachment for this gun for this very purpose.  Has anyone tried one, does it really provide accurate nail placement and depth?<!—-><!—->
Thanks, <!—-><!—->
Erk
  1. DanteO | Sep 02, 2005 02:01am | #1
    I have a couple of them, you will really feel sick when you see how simple they really are for $30 each.  They do a decent job of gauging the depth of the nails once you get the air pressure right.  Every few sheets will get a nail that needs loosened if you have a pretty uniform substrate.
    If you want to try making them out of a small cube of aluminum I'll take a few pics and you can use your current nosepiece as a model for sizing.
  2. JasonPharez | Sep 02, 2005 05:09am | #2
    Erk the RN46-1 has a five position depth adjustment...somewhere between 1 and 3 works best depending on the backing. You shouldn't need a separate attachment.
    Jason Pharez Construction
       Framing & Exterior Remodeling
    1. CAGIV | Sep 02, 2005 08:01pm | #5
      I've been wondering how you faired the storm?
      hope all is well
      1. JasonPharez | Sep 03, 2005 03:53pm | #6
        CAG, I and mine did fine, but my dad's vacation house (that we just finished building) was partially destroyed by a tree. See my post in the Tavern :Katrina: Ground Zero Update for more.Jason Pharez Construction
  3. MRinger | Sep 02, 2005 01:55pm | #3
    Hey I use the vinyl attachment about 7 years ago (using an older model gun)and I've install vinyl on new and old home for 15 years. So I install the attachment (I'm a tool freak, what can I say) and use the gun for few of job "I did not like it" one thing I disliked was the pressure varied so the nail was to far in or out. The cheaper model of siding has a thin nailing flange (not like Certianteed Monogram) so the attachment did not fit in the nail slots, I was pulling out the vinyl so the gun would fit. The list of complaints goes on and on. So I would not recommend it, use the $30 to fill your truck, Damn the gas prices............
    FYI: Wolverine/CertainTeed Millennium has the PermaFlex Hem it does'nt need the vinyl attachment so roofing or staple gun works great!
  4. erk | Sep 02, 2005 04:45pm | #4
    Thanks for the quick responses.  For $30 I'll probably just grab one and see what she does. If I don't like it I'm not out much.  To bad I have a RN45, which doesn't have depth control (at least I don't think so, It's been a few months sine I used it).
    Thanks,
    Erk
  5. USAnigel | Sep 03, 2005 05:24pm | #7
    Changing air pressure is NOT going to give consistant results when driving any kind of nail into wood! The only way is to limit the travel of the parts in the tool being used.
Drafting the 2027 IRC
  • The New Old Colonial
