i have a 9170 wagner sprayer. started loosing pressure in middle of job. it had paint coming out of the slot in the front. is tere supposed to be a plug in thisl slo?. does this mean i need to rebuild the pump? thanks
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
